Hi everyone, so I had the Tesla Wall Connector installed on Jan 4th in that bottom left breaker with a new 60 amp breaker. This past weekend I rented a Model X for a roadtrip and finally got to test my wall connector. With the setup from how Tesla configured my Neurio CT clips (being on the AC only), it did not detect any drain from the wall connector. So I moved the CT clips to be on the main power coming into my panel after the meter (see post #5's picture above, left side shows the two large cables coming into these 3 breakers). After moving it there, it did correctly measure a load while charging the X.
The problem I have now is, after moving it, it seems my numbers are way off. It's showing things like the solar producing 10.4kW (even though I have a max of 6.6kW) and it also shows the solar feeding directly to the grid and nothing to the battery or the house. If I move the CT clips back it seems to go back to normal, but then it's not measuring the load from the wall connector. Since having this discussion I've installed another non-Tesla Neurio in another house so I'm much more familiar with the admin page and such. Do you think my issue is that a configuration change needs to happen to account for moving the CT clips to the main lines rather than on one of these other ones? I've sent an email to
[email protected] but nothing yet.
Another thing that has occurred that I was not expecting is that when charging the car overnight, it did draw power from my battery. I didn't think this was possible because the only breaker that is backed up is my house subpanel and not the breaker for the AC or the wall connector. I just didn't think that would happen, but I guess it will feed energy to my entire house even though my whole house isn't theoretically backed up (or so I thought).
