Ampster
I have a non Tesla Neurio but it only has room for two sets of CTS. Is your model Neurio different or do I understand that two sets of your CTs are spliced together in parallel?I have 3 sets of CT's for my one Neurio.
Which software version are you on? Not sure if it matters. When we tried this when I was on 1.15.1, it wasn't consistent. Certain things worked fine but others did not work. It could be because I do have a split in my CTSwell Energy came out to do some additional documentation on my system today. I had previously e-mailed Powerwall support about the configuration of my system (as mentioned above) and they passed the ticket to Swell Energy. While the tech was at my house he moved the Grid CTs from the grid input of the Gateway transfer switch to the main bus immediately after my main breaker. I have a 400 amp panel that can take two 200A main breakers. I only have one main breaker installed and it is connected to the breaker bus with thick round copper wire and the CT's were placed around these cables. The tech had an extension wire that already had the same connectors as the Neurio, so he just had to fish it through the conduit between the Gateway and the main panel. We did a test charging my Model 3 with varying current and watched the Powerwall page of the Tesla app update as the power flow changed. So, my Powerwall system now correctly measures the total grid draw and can offset but not back up the loads in my main panel.
I have both a Tesla version and regular store-bought version (for another house). They are basically identical, aside from not needing the antenna. I don't know if they are in parallel or serial but yes they are spliced together. After you do that though you have to play with the advanced options. I tried monitoring a sub panel on my other house by using a single CT on phase A and the other CT on phase B of my solar breakers then doubling it up (put a value of 2 in the advanced boxes instead of 1). I feel like it almost worked but kept running into weird issues so I abandoned the subpanel measuring.I have a non Tesla Neurio but it only has room for two sets of CTS. Is your model Neurio different or do I understand that two sets of your CTs are spliced together in parallel?
I am still on 1.15.1. The tech went through the software upgrade process in the Wizard, but it did not change the version. My setup is very straight forward with one pair of CTs measuring the main grid and another pair of CTs measuring the solar. The only thing slightly unusual is that I have two circuits of Enphase micro-inveters, so there are two wires running through each solar CT.Which software version are you on? Not sure if it matters. When we tried this when I was on 1.15.1, it wasn't consistent. Certain things worked fine but others did not work. It could be because I do have a split in my CT
I would not expect a single CT to measure correctly unless it was only measuring pure 240V circuits. This should work with solar. However, a typical subpanel has 120V loads on both sides of the neutral, so you would be doubling a potentially imbalanced value.I tried monitoring a sub panel on my other house by using a single CT on phase A and the other CT on phase B of my solar breakers then doubling it up (put a value of 2 in the advanced boxes instead of 1). I feel like it almost worked but kept running into weird issues so I abandoned the subpanel measuring.
I have another weird case that I thought of when planning a partially off-grid test of my Powerwall system.
I am planning to run my household loads exclusively on solar and Powerwall for a week now that my solar generation is near the annual maximum level. In order to do this, I would turn off the breaker feeding the Gateway while leaving the main breaker on so that I can charge my cars from the grid as needed during the test. The question is, now that my Grid CTs are on the actual main outside the Gateway, will it freak out if it gets grid draw reading while the Gateway is actually in backup mode? Just thinking out loud here...
In the Neurio advanced panel you can double the value. So if it's balanced across the 240v, you can double it so that it's a close approximation of both. This part worked in my testing, I was having issues with other values not working. Again this is not the Tesla's version of Neurio, but the regular Neurio itself (I have this on a different house).I am still on 1.15.1. The tech went through the software upgrade process in the Wizard, but it did not change the version. My setup is very straight forward with one pair of CTs measuring the main grid and another pair of CTs measuring the solar. The only thing slightly unusual is that I have two circuits of Enphase micro-inveters, so there are two wires running through each solar CT.
Yea basically it looks something like this (this was a sample test when trying to figure it out, this may or may not work so don't look at the exact positions closely):Interesting. Tesla's Install Wizard doesn't offer a doubling, just flipping a value:
Your Neurio config looks different from mine:Yea basically it looks something like this (this was a sample test when trying to figure it out, this may or may not work so don't look at the exact positions closely):
Yea exactly, this is not my current setup. I was experimenting with doubling the value of a single CT as recommended by Neurio support. I abandoned this idea (the submeter) since I couldn't get it completely working.Your Neurio config looks different from mine:
My solar CTs are #3,#4. I have 1's on 3/4 so they contribute to the Generation channel. I have ones on all of the CTs so they sum on the Consumption channel.
Ah, maybe it's because you're using CT 4 for the submeter, so you can only use CT3 for solar.
Short answer: No. My results are not consistent with those videos. I don't know what is wrong with his system or loads that is causing the Powerwall to shut down periodically. My system has been rock steady. I have two Powerwalls, so they may be more resilient.I would be curious to see if your results are consistent with these results:
I have run my Powerwall system with the grid connection to the Gateway turned off for about 6 hours this evening. It was running in Self Powered mode when I turned off the 125A breaker feeding the Gateway so there was basically zero grid draw at that time and there was no discernable interruption to the household loads. I had one desktop computer running without a UPS and it did not shut down or reboot. However, I am charging my car from the grid right now and the Powerwall app is indicating that it is confused by the fact that there is Grid CT signal but no power at the Gateway input. The Home and Solar quantities in the app periodically spike up and then go back down. Clearly that is impossible because it's nearly midnight. This only happens now because my Grid CTs were recently moved from the grid input of the Gateway transfer switch to my actual main utility feed. If it was an actual grid outage, this confusion would not present itself.
