TexasEV
The effort they spent in bringing out this non-universal mobile connector would have been better spent on making the 14-30 and 10-30 and 6-50 UMC adapters available again.
With the emphasis on "overhang" in the description, and the fact that the original UMC is still available, I feel like this is more of a HPWC supplement than a sign that Tesla is moving away from outlet adapters. A lot of people use the UMC at home with a 14-50 outlet and pretty much just leave it as a permanent installation. Some of us (I did this) wire the HPWC to a 14-50 plug as a sort of hybrid solution. This is kind of an official version of that, almost.
Anyway, I hope that's true, because I want Tesla to have lots and lots of different outlet adapters!
Hope you're right. My concern is that the current UMC would be discontinued when supplies are exhausted. We will see...With the emphasis on "overhang" in the description, and the fact that the original UMC is still available, I feel like this is more of a HPWC supplement than a sign that Tesla is moving away from outlet adapters. A lot of people use the UMC at home with a 14-50 outlet and pretty much just leave it as a permanent installation. Some of us (I did this) wire the HPWC to a 14-50 plug as a sort of hybrid solution. This is kind of an official version of that, almost.
Yeah, I think the writing is on the wall with that.Hope you're right. My concern is that the current UMC would be discontinued when supplies are exhausted. We will see...
That said, I wouldn't be too surprised if Tesla did so, and attempted to standardize on 14-50 as part of a drive for simplification. I would be extremely disappointed, but not too surprised.
I hope that the current UMC would not be discontinued. I see it more like mikeash where it serves like a semi-permanent EVSE (where the current UMC sticks out more because of the adapter).Hope you're right. My concern is that the current UMC would be discontinued when supplies are exhausted. We will see...
They almost already have that with the umc. You would have to see the actual plug on it to tell if they enabled any sort of extend ability.I suppose it's possible they could do something similar to what TurboCord does as their charger supports both 240v and 120v with just an add-on plug.
Perhaps Tesla will make 14-50 the default plug and then have add-on plugs for 5-15, 5-20, 14-30, etc.?
That sounds just like what the UMC 14-50 adapter does. I don't see how it's safer (not that the UMC and adapter is unsafe at all).
I agree. I think this new charge cable is simply another choice that owners can purchase. I do not expect Tesla to discontinue the cable and adapters that are currently shipping with new cars. That would not make any sense. 14-50 outlets are hardly a universally available plug.I feel like this is more of a HPWC supplement than a sign that Tesla is moving away from outlet adapters. A lot of people use the UMC at home with a 14-50 outlet and pretty much just leave it as a permanent installation
Tesla really needs a more comprehensive redesign of the UMC. They need to have the following:
1. Larger current carrying pins on the adapter
2. Thermal sensing in every adapter
3. Current indicating resistors in every adapter
I think a 9"-12" tail for each plug type and a robust locking intermediate connector is needed. Whether that connector is inline on the line cord or on the body of the UMC doesn't really matter. In this respect, the Type-2 UMC is a much better design.
Basically, yes, but those are hand made from commercially available screw-together parts so they are expensive. They also don't have any thermal sensing. Do they even indicate the available current of the corresponding plug?You mean like this?
Tesla — Universal Adapters - Available in North America Only
I've thought of doing this to gain a longer cable, but otherwise what is the advantage of adding a 14-50 plug to the HPWC? A 14-50R can only safely support 40 amps, the max that the UMC supports, so the only benefit I see is having a longer cable. Am I missing something else?Some of us (I did this) wire the HPWC to a 14-50 plug as a sort of hybrid solution.
NEMA 14-50 plugs are rated for 40 amps continuous. The 80%/125% rule for continuous currents, can't recall what it's called.I've thought of doing this to gain a longer cable, but otherwise what is the advantage of adding a 14-50 plug to the HPWC? A 14-50R can only safely support 40 amps, the max that the UMC supports, so the only benefit I see is having a longer cable. Am I missing something else?
