Darren Donovan
Tesla doesn't support 1 pedal driving. I only think that Nissan supports it. It's in the 2018 and newer Leafs. My wife loves it.
Chevrolet Bolt will stop completely with the regen paddle on the steering wheel.
Same hereThat’s a great point.
Drives me nuts when I see posts that say they almost got into an accident because they had no or low regen. You should be prepared to instinctively use the brakes at any time.
I barely notice if I have high or low regen. I just automatically adjust without thinking about it.
That's unlikely to be the case with the Model 3 rear drive unit.The motor on the Model 3 can't regen down to 0- there's some fairly detailed tech explanations why out there if you want to find em
Took delivery of my SR yesterday. Love it. Took me less than 15 minutes to get used to regenerative braking and one pedal driving. So....why won't the car completely stop with regen? Why make me use the brake pedal for only 4mph til 0, then hold and I can remove my foot from the brake?
A little secret, you can stop to 0 at will without fiction brakes. Around 5 mph you can drop the gear selector into the reverse direction and use the accelerator to actively slow down the last bit. Wouldn't recommend regularly doing this on the roads though. It is helluva tricky use (sometimes you have to switch twice, on some slopes), and likely violates local traffic laws to do it. There is often a law that disallows a reverse light while traveling forward, I know there is in TX. I haven't confirmed if the Model 3 puts on that light when you're rolling forward but in reverse gear but it is quite possible it does.
The Bolt will stop completely without using the brakes in S, L and any combination with the regen paddle. The paddle just changes the amount of regen with L+paddle having the most aggressive regenChevrolet Bolt will stop completely with the regen paddle on the steering wheel.
Circumstances heavily motivated me.I hear an echo! Unlike me, it sounds like you actually try this sometimes though? Seems like a lot of work.
Newb Q--why must I use the brake pedal at all?
In 'D' though it is kind of academic, because it takes so long to stop w/o using the paddle.The Bolt will stop completely without using the brakes in S, L and any combination with the regen paddle. The paddle just changes the amount of regen with L+paddle having the most aggressive regen
Newbie here, so feel free to correct me if I am wrong, but isn't it also a good idea to hit the brakes to slow down so drivers behind you see your brake lights?? if you never hit the brakes it is just like driving a car with broken brake lights??
If you're on Normal your brake lights do go on often. If you watch the screen it'll show you when that happens via lighting up the taillights of the car avatar.Newbie here, so feel free to correct me if I am wrong, but isn't it also a good idea to hit the brakes to slow down so drivers behind you see your brake lights?? if you never hit the brakes it is just like driving a car with broken brake lights??
Another clue that the Model 3 motor is not using those rare-earths in a conventional permanent-magnet motor design is that the car does not do regen all the way down to 0 miles per hour.
Yep...I like using L mode which is about the same as the Mod 3 most agressive regen mode...but the Bolt comes to a complete stop. For faster stops/agressive braking...I like to use L÷paddle and feather the throttle to control regen braking.In 'D' though it is kind of academic, because it takes so long to stop w/o using the paddle.
Unfortunately in a much ruder way. Wish they would have made it less jerky, hopefully they fix that with their new models they bring out because as is it is inferior to Tesla's ride experience. The brake pedal feel isn't even close either but they probably can't fix that much, why I expect Tesla went the other route and didn't put any regen link on the friction brake pedal.Yep...I like using L mode which is about the same as the Mod 3 most agressive regen mode...but the Bolt comes to a complete stop.
As remlamasi already pointed out- it's exactly the case with the Model 3 rear drive unit
Tesla Model 3 Motor — Everything I've Been Able To Learn About It (Welcome To The Machine) | CleanTechnica
Besides the brake lights come on when regen is over a certain amount, standard transmission cars have never activated the brake lights when gearing down. It's a non-issue.Newbie here, so feel free to correct me if I am wrong, but isn't it also a good idea to hit the brakes to slow down so drivers behind you see your brake lights?? if you never hit the brakes it is just like driving a car with broken brake lights??
That's a pretty dumb thing conclusion they draw there given that it is a mirror of Model S behavior thus there is a much simpler, more obvious reason for Tesla to have the behavior like it is. That it is familiar to existing customers and a very successful behavior.
Both the induction motors (used in S, X, and front motor of AWD 3's) and the PMSR motors (used in rear motor of 3's) need a magnetic field set up inside the motor in order to convert current to torque (acceleration) or counter-torque to current (regen). You must use a small amount of current from the battery and send it through the windings of the motor in order to set up this magnetic field.
Below 5 MPH, the amount of power required to set up the magnetic field exceeds the amount of power you can create from regen, so there is no point in attempting to recover that power. Theoretically you could do it and allow the motor to slow the car to 0 MPH, but that would actually result in a net power loss, so it's more efficient to just use the friction brakes.
The Leaf and other EVs that use straight permanent magnet motors can regen all the way to 0 without this efficiency loss because the permanent magnets are responsible for setting up the magnetic field. No power from the battery is necessary.
The small permanent magnets in the Model 3's PMSR motor are not powerful enough to set up the magnetic field, they are only there to smooth out low-speed torque ripple which is inherent to the reluctance motor design.
