eledille
TMS 85 owner :)
Iz: Eco-mode regen is a mistake.
IMNSHO, there are only two ways to do regen right: Applying a variable amount of regen when letting off the accelerator, or applying a variable amount of regen using the first part of the travel of the brake pedal. The Roadster does the former, the Think City mod. 4 that I have does the second - releasing the accelerator causes the car to simply coast. When going downhill it will regen to keep the speed constant, and you can switch on minimum regen by briefly touching the brake and switch it back off by briefly touching the accelerator.
Mixing these two might also work, i.e. applying regen as you release the accelerator, and adding even more regen when braking.
I'm used to control the braking of my cars, ICE and electric alike, with the brake pedal and acceleration and engine drag with the accelerator. Why start mixing in levers and modes when you can have total control using only the pedals?
The new Think City mod 5, the Leaf and the MiEV have eco-modes. I've tested the Think City 5 and the MiEV, and I dislike having to switch modes with the gear lever. With my old Think I can get precisely the desired speed in the desired amount of time using only the pedals. In the newer cars, normal regen is too weak, and in eco-mode acceleration is limited. Gah! I can limit acceleration myself if I want to!
Eco mode might be a good thing, but please keep the regen separate - in fact, weak regen is often more economical than strong regen - you release the the accelerator earlier and coast longer. Average speed drops together with consumption.
