CactusOne
Here is my setup with version 1...
I used a USB hub to power Jedda..no battery needed.
I received the new version today with no battery. Works great. Charges 2 iPhones at once. Fit and finish are excellent.
Ok cool, I’ll order one now then. Thank youIt came with a $5 bill to cover the cost of the splitter. The cables are indeed long enough.
Thanks for the intel!It came with a $5 bill to cover the cost of the splitter. The cables are indeed long enough.
Just to be clear, do we need to plug in two cables with the Nomad? If so, and they send along money for the splitter, do they recommend which splitter to purchase?
I'm almost positive (almost!) that you only need both cables plugged in if you'd like to use both sides of the charging pad. OK for one cable only if you only plan to use one side of the pad. That's how it worked with V1 of the pad. Somebody should confirm that this is still the case?Yes you need to plug both cables in. They recommend the Onvian male to female splitter.
And are the cables long enough to plug in AND open that shelf all the way??
So there's a pretty lid on top. Hidden below that is a hinged "shelf." I'm calling the thing where the phone sits (and the charge pad sits) the "shelf." Can you lift that hinged shelf all the way as high as it will go when the cords are plugged in (or being plugged in)? The initial cable length was so short that I could just barely lift that shelf enough to reach under there blindly to plug them in. And once plugged in, if that shelf were lifted too high (to reach something in the bin below, perhaps) it could easily damage the cords or the connectors or both.What do you mean "open the shelf all the way"?
Well, that's curious. I've never seen Nomad claim that both sides will charge with just one cord. Thanks for the intel!Incorrect. Just got mine today, only plugged in one cable, I can charge two iPhone X’s side by side. Not sure how fast they will charge, but it’s working.
