Mine does that too if you turn the wheel lock to lock while not driving.
Try it again with "brake hold" off.
What year is your car? Tesla applied a service bulletin to my car last year to trim the front wheel well liners due to rubbing. I have a 2013 classic.
I don't know what it is but I think I heard 2 noises:
1) very low volume rapid "rrrrrrrrr"
2) louder volume creaking.
Do they still happen while the car in motion and high speed?
My S90S was purchased in December and has less than 3000 miles on it. The noise is heard when pulling into and pulling out of parking spaces when you turn the wheel to one side or the other. For the first 2900 miles it was not present but only started doing this noise the past week.
I...turning...
Tesla uses an electric motor for power steering and doesn't suffer those issues. You can turn the wheel to lock all day long and it won't hurt anything.It's the power steering. Happens on all cars.
My last car's owner manual specially mentioned it, and even cautioned against holding the wheel at full lock for too long as it strains the system.
Edit: sorry, my mistake. Your sound is not what I was remembering.
Sounds like a quick and fix from 2013 post:
Turning noise..... | Tesla
"docdac | July 22, 2013
I just had this fixed today by a Tesla Ranger under warranty. The two bolts that secure the steering rack had to be torqued down. Now, no more clicking while parking and tight turning. It is a known issue by the service people and a quick easy fix."
Where is this break hold setting?Like I said, it only happens on mine when I'm stopped and the brakes are on hold. When you turn the wheel, the weels rotate a faction of an inch or so since the wheel isn't perfectly centered over the steering knuckle. The result is the brake pads slip in fits and starts on the rotors. If I don't have brake hold on, it doesn't make this noise.
Here you go. With brake hold on and brake hold off.
