Has anyone used this in the past week? I was going through on the weekend and since I just has CCS2 installed in my S I thought I would give it a go. Plugged in, pushed all the correct buttons and it started to charge at 50kW** then 2 seconds in the charge cut out and the NRMA charger displayed "error". I tried it 3 times and it did the same each time so I called NRMA to report a fault but they said it wasn't showing any faults. I then thought maybe my CCS2 upgrade wasn't working correctly, so I trundled on down to Heatherbrae SC and tried the CCS2 on the Tesla SC and worked perfectly - started at 126kW and I charged up to 80% (finishing at a charge rate of 54kW**)
I'm still thinking there is a fault with the NRMA charger, so would be good to hear from anyone else who has used it recently.
**bit disappointing that the NRMA charger at Nabiac is only 50kW..unless you are desperate it just isn't worth stopping unless you want to spend an hour or more stooging around Nabiac
