Yep... I posted about this a few pages back... 100% nuclear may indeed be cheaper than 100% Solar/wind/Storage for the exact reason that you stated... trouble is that there's no way to get there absent central government control... since 0-20% solar PV doesn't require storage (Solar is ABSOLUTELY cheaper) and >20% Solar/wind nuclear begins to suffer from depressed capacity factor...
Additionally
http://en.wikipedia.org/wiki/Swanson's_law is very likely to continue for several more decades... building out excess levels of solar PV in 20 years will likely NOT be cost prohibitive since we could very well be looking at module prices <$.10/w...
Phase 1 (Today - ~2020)
Where we are now is REALLY easy... you just slap some panels on your roof, no need to worry about storage or "self-consumption". To the grid your PV array just looks like reduced load.
Solar is cheaper per kWh than nuclear... even today.
Phase 2 (~2020 - ~2035)
Hawaii and Germany are either here now or getting close... When peak power is 80%+ of demand you're still <20% of total generation. Most grid-tie inverters CANNOT regulate voltage and frequency. They are on or off; they are inverting 100% of what's available from the panels or they produce nothing. This would need to change to expand past ~20%. Germany has "smart" inverters that can be active participants in grid stability. When frequency gets too high they can curtail power or preferably divert power into a battery bank. Demand Response and small amounts of storage become critical. SMA has already developed solutions. They are starting to bundle inverters with a 4kWh battery pack and they've got what's called the "Sunny home manager" http://www.sma.de/en/home-systems/so...tem-smart.html I wrote an anti-net-metering blog and this is why... we've got to dump "net-metering" LONG before "phase 2" Investments in "smart home" technology are worthless with "net-metering" in place. Solar "would" start to lose it's cost advantage with nuclear... but as the capacity factor of nuclear falls the capital costs increase on a per kWh basis.
Phase 3 (~2035 - ~2050)
IMO going from 80% => 100% wind/solar is probably going to be harder than 0% => 80%. My prediction is that we'll likely have sufficient solar PV installed to completely displace fossil fuels but be unable to due to a lack of storage and the disparity between summer/winter insolation... but... unlike nuclear, so long as it's cheaper to install solar than import power from the grid we will continue to build out solar PV FAR beyond what is 'needed'. The path to >80% solar/wind is probably the day when we've got so much excess energy during the summer months that there's nothing better to do with that extra energy than split water. The hydrogen can then be stored for later use.
Keep in mind that the cost of equipment will likely continue to fall... even though "smart" inverters will be more sophisticated than the grid-tie inverters we're using today I would expect the cost to be the same or lower. Similarly even though we'll need an overabundance of solar in "phase 3" with module prices expected to fall <$0.30/w in 2020 that won't be a problem.
While my premise has always been that solar is cheaper than nuclear the fact I'm 100% certain of is that there IS an economically viable path to 100% solar/wind while there IS NO path to any reasonable expansion of nuclear... let alone >50%. 100% nuclear could in fact be cheaper than 100% solar but with the cost point of solar where it is there's no way for nuclear to expand. The window for nuclear expansion was in the 70s, 80s and 90s... cheap solar has slammed that door HARD.
- - - Updated - - -
The bottom line is that people are going to keep installing solar... absent a law prohibiting self-generation (Anyone seriously want that or think it's possible?) the duck curve WILL happen... it's inevitable... the question is how does the grid take advantage of and cost-effectively integrate intermittent sources like solar? In almost every way nuclear is the WORST fit...
