LOL... Really?
Because I've spent 15 years in the nuclear industry... I understand it. Because I've spent ~8 years installing solar... I understand it. Do you want this thread to be an echo chamber of pro-nuclear fanboys or do you want facts and understanding?
We have several lengthy discussions and you wrote it all of as a fantasy. So, I'm a fanboy.
You also ignore the over a dozen times when I explained you
only really understand that exact type of reactor you worked with. In your mind a nuclear reactor has only of type of electricity generation turbine, that turbine required by a 250C temperature outlet reactor. When there has been several reactors that produced heat at 600C or higher. Which lead to a much simpler turbine. In your mind every accident scenario for old water cooled reactors apply to all of them.
You most certainly are fully self assured of your beliefs. Like I said before, there's no point in discussing here, since those with an open mind don't post, only those with a 100% closed mind to what nuclear power can and will be.
Before I go, and this time I'll try to stay of nuclear discussions until 2022, I'll say this again, if you are SERIOUS about dealing with climate change we need nuclear. Most of all we need nuclear for industry that requires process heat 500C and hotter. To make fertilizers, to make hydrogen, to free up gas burning from oil refining (which will stay with us for as long as there's oil, at least for to make the feeds for petrochemical industry).
Finally, if climate change hits really hard and large scale desal is required, high temperature nuclear is perfect cause the cooling requirements for a large nuclear site can boil seawater by the billion gallons / day.
nwdiver your knowledge of nuclear power is of little use for discussion here, cause your mind is closed about nuclear.
I on the other hand am interested in all non fossil fuel energy sources. Hydro, solar, wind, nuclear, geothermal and more.
I'm not one cent more of a fanboi about Gen IV MSR nuclear than we all were about Gigafactory when the first plans about it were broken out.
