Tomorrow is the greatest minus figure I've seen. They're paying you almost 5p a Kw on the afternoon of the 21st April
It is pretty good from late morning...
It is normally slightly cheaper but the grid utilisation is down significantly at the moment so the prices are lower on average. I would say an average is around 9p/kWh over a 24 hour period with a bad day being 11p/kWh. In April a bad day has been 8p/kWh average.Is it worth considering switching to Agile if I only charge the car with it? I've always thought Go would be more consistent, but looking at recent graphs Agile has been consistently cheaper over the same periods of time, and lately - as above - actually negative.
... but if you want a guaranteed 4 hour at 5p kWh charge window (other fixed tarrifs also available) that you can rely on day in day out ...
The electrical connection is only used to charge the car. It is a second physical electrical connection with only the car charger connected to it, so to answer your question - there is no usage between 4-7pm unless I decided to charge the carThe answer depends heavily on what you use during the 4-7pm period.
If you are a light user in that time period then yes, Agile will often work out cheaper for you, but if you are heavy user in that slot then no, Agile is probably not the best choice for you.
I don't know really. I would presume the car would decide how long to precondition for based on the temperature etc? IME of the BMW i3, it seemed to start drawing power a good hour or so before the departure time, though I could be mistaken (I stopped it doing that pretty quickly).How long do you expect to precondition for? 15 mins (or less) at 7kW will probably cover the majority of cases so under 2kWh, which is 12p between ~14p/unit on Go and 8p on Agile. Remember, you would have potentially just saved around 3p/unit on Go 4 hour window, so an average overnight charge of 4kWh will wipe out the preconditioning saving.
