Hi,
I have posted here as I can’t find a a clear answer to my query.
I have 3 Powerwalls and zappi charger which is supplied via Powerwall, so it sits between grid and charger. I don’t have any Solar PV.
This set up is fine for fixed off peak tariff as Powerwall lets grid charge the car and charges itself in that off peak time.
However, on Octopus intelligent , when I plug in the car, the Powerwall starts charging the car as per octopus intelligent schedule and starts draining Powerwall.
I have checked with Tesla installer and he says that all installation they do has Powerwall installed in a way that it sits between grid and all electrical supply to house. They have not encountered this issue as all battery storage systems use off peak tariff (in which most people charge both cars and battery) and only Octopus intelligent tariff has smart charging as well as off peak supply so you can charge battery at off peak time but car anytime via app.
The quick solution is to connect car charger directly to mains and I asked the installer if we can connect charger directly to mains so that Powerwall does not control the charger but he has not done it before.
Has anybody else have a set up with Powerwall installed totally independent of car charger and does it work fine?
Will it cause any warranty issue?
