Octopus Go, How to set M3 to charge 00:30 to 04:30?
Jan 11, 2021
97
133
Bristol
I just start changing at 00:30 and mostly that works for me. Where it does run beyond 04:30, I’m only paying 14p KWh, just 9p more than the cheap rate, and that is still way cheaper than public or super charging.
Reactions: M3noob
Jason71
3,038
3,045
Shropshire
Why there isn't a simple start and stop time nobody knows .. and maybe it will change in a software update. (There are a number or reasons I can think of but not to have start and stop as one of the timer options does come as a surprise.)
I know.
Its the same reason there are no waypoints. Tesla/Elon think they know best. They want to keep things simple so only include the minimum options and the ones they chose are the ones that make sense to them in their environment / use case. If you look at the manual in the description of "scheduled departure" it says "NOTE: Your vehicle aims to finish charging before 6am (end of off-peak hours)" So they acknowledge the concept of off peak but base it around some fictitious fixed US concept of it and tough to everyone else.
nufan
126
116
UK
I set it to start at 0030 - and, knowing I get +10% per hour at home - set the charge limit accordingly with a backup of TeslaFi ordering a stop at 0430 if plugged in.
HTHs
Reactions: Kenners
Kenners
207
187
London
HTHs
Exactly this, you get 10% per hour in a long range and a bit more in a SR+, so you can probably get from 30-80% in that four hours. If you plug in every night as Tesla advise its never a problem.
I think Tesla still only develop things based on how they work in California, which I guess will soon change to how they work in Texas!
Mar 15, 2021
237
423
Essex
Sorry if I’ve for this wrong, but I assumed all smart home chargers had a timing facility. I have a Zappi and it’s really easy to set the times I need.
