We have a winner! Except it wasn't "possibly" installation error, it *was* installation error. The arrows (^) on the protective vinyl *must* be lined up with the "^" mark etched into the glass. You really should have good light when doing this because the arrows are not very large and require a viewing angle that makes them stand out.
A lot of us have installed the rack easily with no issues. While I have an accurate torque wrench that I used, it's not really necessary if you have a reasonable level of mechanical competence. The reason I say this is the retainers are welded to the steel frame which is very strong and tightening the bolt draws the rubber pad on the crossbars onto the top surface of the metal roof frame very close to the retainer. So over-tightening can't deform anything enough to cause the glass to break. The way the glass could break through over-tightening is if the tightening draws the rubber pads all the way down to the glass. This can be checked visually. All of mine, tightened to spec, did not even touch the glass. Just check visually when tightening to ensure the rubber pad doesn't contact the glass. The torque spec is not very high because the bolt is designed in such a way that it's captive (rotationally) once installed and cannot rotate or back out when the rack is installed. In other words, the bolt does not rely on tension to keep it from backing out once the rack install is completed.
I said “possibly” to give him the benefit of doubt....camera angles can play tricks sometimes lol. I agree....Have seen posts showing the welded retainers and don’t see how the glass could break if installed properly. But then you have posts like @Marius A that report cracked glass with proper installs. Did you notice popping/cracking sounds that others reported when tightening down the nut? Could it be a QA issue ie with the welded retainers or installation of the glass?
