jordanair45
2019 Model 3 SR+ w/ FSD
you do realise wind resistance on the rack will create more than 4nm of force? in the reagon of probably 2 orders of magnitude more?
Did not. Thank you
4nm of torque is not the same as force.you do realise wind resistance on the rack will create more than 4nm of force? in the reagon of probably 2 orders of magnitude more?
Thanks for sharing the article on torque vs tension, good information. I take my racks on and off between uses because I am a windsurfer and it may be days or weeks between sailing sessions and I don't want the unnecessary wind drag. My solution for tightening is to use minimum hand tightening till the assembly doesn't move fore or aft. Having achieved that level of securing I don't believe the wind forces can cause the clamp to dislodge. Six trips at highway speeds have confirmed my expectations.4nm of torque is not the same as force.
Bolt Torque versus Tension
wrong thread?Tint place I used has done 800+ Model 3's. They have gen1 and gen2 rear glass they purchased from Tesla which they use to size and cut the film (so they don't have to do it on your car). They said at some point tesla switched to gen2 which is thicker and tougher.
Impressive!!View attachment 464651 View attachment 464652 View attachment 464653 Just came home from my autumn break in Norway. Drove about 1000 miles at speeds up to 100 mph. (...without the bikes...) Just ordered a torque wrench for future use.
Buy the hitch adaptor from the USA that comes without the ball & hence is like a ‘2 piece lego’ systemYour hitch in picture #1 appears to end in a ball. How does the bike rack attach to that? I would have expected if it's on a ball, that the weight of the bikes would make it just rotate down and drag on the ground. What makes it stay up?
So this just happened to me. Used a torque wrench set at 5NM. Roof cracked. Definitely returning the rack and won’t trust it from here. New glass coming in a few days... ughh.
Glass was all replaced now to figure out what to do about roof racks
1250.00 yayh lolCongrats! How much was the cost to replace the glass, may I ask?
hello Everyone,
Went to install my roof racks OEM Tesla and they cracked the front glass.
I am at a loss for words right now.
How the hell does this even happen. I’m no moron literally hand tightened.
View attachment 443858 View attachment 443859
hello Everyone,
It looks to me like it was possibly installation error That caused the glass to break. Zooming in on the picture it looks like the arrow of the protective sticker(and center of the hook when installed)is not lined up with the arrow in the glass. It looks to be lined up with the line behind the arrow. I checked my car and it looks like the arrow is further up where I marked the OP’s picture. If you look close you can see a faint v and behind it where he has the sticker centered is a faint line. The arrow in the glass is where the middle of the metal mounting tab is. And is where the hook is supposed to be centered to. Second pic is what I’m referring too.
