"Official" recharge times
Discussion in 'Roadster: Technical' started by TEG, Nov 19, 2008.
  1. TEG
    TEG TMC Moderator
    #1 TEG, Nov 19, 2008
    We had pretty much deduced this by doing the math, but here are the "official" numbers of hours to fully recharge a Roadster as seen in the 2008 Roadster owners manual:
    Charge Time / Connection
    4 hours - [email protected] <== Tesla Home Charger
    5 hours - [email protected]
    6 hours - [email protected]
    7 hours - [email protected]
    10 hours - [email protected] <== old RAV4EV/RangerEV "Level II" standard
    15 hours - [email protected]
    18 hours - [email protected]
    20 hours - [email protected]
    40 hours - [email protected] <== Common household outlet
    Interestingly they say you can define different current limits for different locations and it uses the cars GPS to determine if you are parked at a particular charger that you want to have set for a particular current limit.
  2. graham
    graham Active Member
    Aptos, California
    The manual is saying 4 hours, but I am still hearing the media quote 3.5 hours. Is the manual rounding up? Have Tesla changed their claims?
  3. Kevin Harney
    Kevin Harney Active Member
    Herndon, VA
    Can the charger handle anything over 240/70? Is anything over that possible in a typical US household ?
  4. TEG
    TEG TMC Moderator
    Many US households can't even do that without upgrades.
    I don't think they support anything higher for home use.
    I suspect they have been experimenting with a much higher current commercial fast charge station, but that may require a different connector to the battery pick if they ever do it.
  5. graham
    Aptos, California
    If I recall properly, the cars internal charger can handle higher current, but 70 amps is the biggest circuit you are allowed in a residence in the U.S. Tesla have hinted that it might be possible in the future to have faster recharge times plugging the car in at a business with a bigger circuit. To my knowledge they have not created a wall charger capable of that for businesses yet.
  6. tomsax
    tomsax Member
    Sammamish, WA
    Charge Mode
    The times TEG quotes are for the "Standard" charge mode. If the mode is set for maximum range, then the charge times will be "approximately 15% longer."
  7. malcolm
    malcolm Active Member
    Tesla have talked about the possibility of three-phase but a) if you're used to several hours of overnight recharging and b) more power means more energy needed for cooling I can't see any advantages until supercaps get established.
    At present, faster recharging would just damage the batteries: "Avoiding very high charge rates. Charging faster than about C/2 (two hour charge) can reduce the cell’s life."
    Tesla Motors - think
    I'm not sure domestic three-phase will be allowed anyway.
  8. dpeilow
    dpeilow Moderator
    Winchester, UK
    Isn't it already used in pool heaters and Economy 7 heating? I'm pretty sure the electric boiler at an uncle's house is on a 3-phase supply.
  9. TEG
    TEG TMC Moderator
  10. dpeilow
    dpeilow Moderator
    Winchester, UK
    Fair enough. Three-phase in a house is extremely rare here too, but the difference (as I understand it) is that we have three-phase in the street everywhere, so to bring it into a house is a trivial exercise.
  11. vfx
    vfx Well-Known Member
    CA CA
    I was trying to make a "Miles Charged Per Minute", "MCPM", and a "Miles Charged Per Hour", "MCPH" chart for each of the above.
    That way it will be easy to do the 'top off time' math based on available power sources.
    Are we using the 220 miles or 244 miles per full charge these days?
  12. TEG
    TEG TMC Moderator
  13. Kevin Harney
    Herndon, VA
    Aren't most of the 240V services in the US 2 phase ? :confused:
  14. Kevin Harney
    Herndon, VA
    Ladies and Gentlemen,
    Once again the AMAZING TEG INTERNET MACHINE again !!!! Thanks TEG.
  15. vfx
    CA CA
    Thanks TEG,
    So by the these Tesla numbers, the best "by the minute" charge possible is at 240V, 90 amp feed, 70amp draw, is .25 (1/4) miles of travel for every minute charging.
    The slowest (120V 12Amps) is considerably less per minute..
  16. Kevin Harney
    Herndon, VA
    no 56 miles per hour is almost 1 mile /minute.
  17. TEG
    TEG TMC Moderator
    #19 TEG, Apr 28, 2009
    You can just take the bottom entry ([email protected]) from that chart and divide by 4 (1.44kW/5.76kW) to extrapolate for [email protected]
    So,
    20amp breaker, [email protected], ~40hour recharge time, ~4.75 miles added every hour.
  18. vfx
    CA CA
    Right, I was reading it across - as in 56 miles in 3.5 hours. :redface:
