SBD47
If that is your application and desires, I’m not sure why you would’ve chosen this kit. It’s literally one of the sportiest/stiffest kits available. There are multiple better options for your use case. Live and learn. I would either order a softer set of Swift springs or remove the kit altogether and replace with MPP Comforts.Yes. The softest setting.I have a 7 seater model Y. It’s basically a family car. We don’t like to feel the road imperfections, just smooth ride overall. The road and track kit is still too hard in the rear. I guess I should pay extra to get the redwood one or mpp setup
Just a thought…If you haven’t already, you could try adjusting your rears all the way “stiff” and take the car for a drive to feel the suspension. Then adjust the rears all the way “soft” and take the car for another drive to confirm that you are indeed adjusting from the right direction. Is it possible you are actually adjusting the rear stiffer, instead of softer? Wouldn’t be the first time someone did that with this kit.
