I have the V4+. Worked great for 10 weeks until temperatures dropped into the low 30's (F). What I observed was charging behavior was a large grain at start (approx -25 amps for a few seconds) followed by charging at about 9 amps until battery at about 14.8v. Then resting. (all of this using the Ohmmu app). After a bit the car would draw from the battery at about 5-8 amps until the charge level dropped to about 13.4 volts and stop. After that the battery would rest until next drive. No amps in or out. Looking at the service mode menu under LV battery, I would note the Tesla would alternate between charging at .1 amps to discharging at .1 amps. Maybe even less. When temperature dropped into the 30's the Tesla flagged bad battery and allowed 12.5 volts un til stopping. This drained the battery to about 12%.
I should mention my build was an early December 2022 and the firmware may be updated with your build.
I could not do the Ohmmu app reset as I was below 15% that is in the procedure. I removed the Ohmmu V4+ placed on a lithium battery charger at 1 amps. No real charging. So I connected a 6 amp conventional slow charger and raised the Ohmmu to 35% on the bench. Reconnected the 1 amps slow charger (in a cold garage around 40f) and left overnight. I return the Ohmmu was at 34% (it dropped 1% on the charger) and the charger showed fully charged? Reconnected 6 amps slow charger and battery continued charging until Ohmmu app said 100% and it was at about 13.5 volts. My conclusion, an adjustment to the battery was needed. The Tesla reacted correctly sensing a none charging battery and flagged it. I contacted Ohmmu with the findings. In the latest support section they mention:
"IMPORTANT NOTES:
- We have identified the issues causing these errors.
- Ohmmu is currently developing a hardware revision (Rev4+) to resolve this issue for existing customers, which should be available at the end of June 2023."
I am assuming since the last correspondence was the app revision would not only allow data collection to send to Ohmmu one would be able to re-flash the battery with software updates. I am guessing that June 2023.
Since the V4+ is back available, I would guess it has been updated from the build. I would ask. Meanwhile I'm waiting for the app revision. Up until the cold weather failure it worked flawlessly and since the recharge it is sitting on the shelf still at voltage and I should mention all the indicators in the app were always green showed no internal failures. It just would not charge at low amps/low temps.
