Antigravity's Battery Trackers are very handy for monitoring the 12V battery through your Android/iPhone, I've been using one on my MYP during testing for their lithium RE-START Lightweight Lithium Battery upgrade for the past couple of years and tracking logs.How do I check the health of the 12V battery? Replaced early 2019.
Having an easy way to check the health of the 12V without opening up the car would be preferred.
I this on several of our cars and love it.Antigravity's Battery Trackers are very handy for monitoring the 12V battery through your Android/iPhone, I've been using one on my MYP during testing for their lithium RE-START Lightweight Lithium Battery upgrade for the past couple of years and tracking logs.
Antigravity - Lead-Acid Battery Tracker
The Antigravity Battery Tracker monitors your vehicle battery status through your phone or tablet by using our free Battery Tracker App (iOS or Android, Bluetooth 4.0). The app has three main pages: Voltage Test, Cranking Test and Charging Test. The simple interface makes it easy to monitor the...europeanautosource.com
You cannot use one of those monitors that plugs into a 12v port as in the Tesla, those are powered by the HV battery via a DC-DC converter when the car is awake. You will have to connect directly to the battery and, as noted, it will not be accurate unless the car is asleep.
Does anyone that has looked into these 12V tracking devices have a favorite if different from this specific device?Antigravity's Battery Trackers are very handy for monitoring the 12V battery through your Android/iPhone, I've been using one on my MYP during testing for their lithium RE-START Lightweight Lithium Battery upgrade for the past couple of years and tracking logs.
I don’t know what you’re talking about in regards to a monitor that doesn’t connect directly to the battery. The device I have connects to the battery.
I'd use service mode as shown here if I'm curious about battery health. The car detects weak 12v battery and gives you a warning, and keeps the high voltage battery on to give you days of time to change the 12v when required. Plus all kinds of battery monitors designed for ICE cars simply won't record correctly due to different charge cycles of the 12v in an ev.How about looking in service mode? Would that be reliable? Or is that, if the car knew, it wouldn't fail without warning?View attachment 1006727
It is not intuitive, but low mileage is worse for the 12V battery because your car is asleep more of the time and not running on the DC-DC converter. Miles is not a good indicator of 12V battery condition.My car needed a new 12V right at 3 years old, it sits in a 76f garage year round with only 20000 miles. Kind of surprised how quickly it died. Tesla replaced it for free, and the car gave a warning about it. With the newer software updates since 2022, the car simply won't fall asleep and keeps the High voltage battery on at all times when 12v is dying.
Btw, when 12v warning is on, the wireless phone chargers and USB ports and 12V outlet has no power. My phone was dead on a road trip when it happened, quite annoying.
Is it a load tester? If so, the battery should ideally be disconnected from the car to be able to test accurately (if battery is still connected to car and car is asleep, that helps to reduce inaccuracy, but the parasitic load may still create an inaccurate result).I don’t know what you’re talking about in regards to a monitor that doesn’t connect directly to the battery. The device I have connects to the battery.
The Tesla detection method already gives an early warning and will automatically switch the car to keep the HV awake when it detects the battery is on the way out. The problem is that is not 100% reliable.All I was saying is it would be nice if the car had a feature that could read the health of the battery and display it on the screen. I’m not trying to say *how* specifically it would work. A notification that comes after the problem already exists is not a great solution.
I'm using the Antigravity unit on an iPhone 15 Pro Max, and have battery trackers on my Model YP, Truck and motorcycle. I go for sometimes weeks between vehicles (even more on the bike), so it's handy to know whether or not it needs to just be driven around town a little bit or connected to the trickle charger.Does anyone that has looked into these 12V tracking devices have a favorite if different from this specific device?
There seem to be many variations, any that work particularly well with iOS?
Always though it might be interesting to have a few related metrics like ambient/cell temperature to correlate voltage swings.
Anything like that out there, possibly even user definable threshold push notifications, and longer saved logging durations?
There’s a procedure where you kill the power to the car by disconnecting the plug under the back seat. This isolates the 12v battery and you can check it directly.When testing the 12v battery in a Tesla be sure the car is asleep i.e. power it down. Otherwise, if the contactor is closed the DC-DC transformer will be supplying power to the 12v battery.
However, as the car will tell you when you need to replace the battery I would not worry. But if you are concerned just replace it, especially as the Tesla battery is relatively inexpensive.
