There's been chat on various charge point option threads about open PEN fault protection, and why it is needed. Right now we have an open PEN fault, probably as a consequence of storm damage to an overhead nearby, as much of the village is supplied via ABC, and the DNO have told me that a tree has damaged a nearby cable.
Guessing from the symptoms I'm seeing at the moment, it seems probable that the PEN has gone open circuit, that the transformer is way out of balance and that consequently I'm seeing the voltage between neutral and "true" earth (i.e. my earth electrode for one of the charge points) floating between 50 VAC and 85 VAC. We're getting between 260 VAC and 285 VAC in the house (or were until I decided it was safer to isolate the incoming supply) between line and neutral.
The solar inverter seems to have packed up, not sure yet if it's permanently damaged or just shut itself down, and a phone charger's blown (big time, a bang and lots of smoke). I anticipate a claim going in to the DNO, as I took some photos of the screen on my multitester, to prove the supply had gone way outside the safe (and legal) limit before I shut it off. We're running on batteries for now, cut off from the grid until the fault gets fixed.
So, despite the best endeavours of the DNOs to try and make the PEN connections more robust in recent years, with their newer, high integrity jointing kits, it seems that open PEN faults can still occur, and can produce potentially (no pun intended. . . ) dangerous conditions at the consumer end. It's certainly reinforced my view that open PEN protection is essential, and made me glad that the charge point my car is plugged into at the moment still has an earth electrode, given the relatively high voltage that the PEN was floating up to.
