You don’t have to use it. But Hyper seal and Opti Seal help the drying process, provide protection and increase gloss, so why not?I thought the whole ONR idea was superliscious
lubricity. How many more layers of lube are there
to sell? Isn't it a little like several condoms at once?
You'd worry the poor protected skin would pale and
shrivel from lack of sun and air! ;-)
I really just wish the DI water systems were cheaper, then we could let the car air dry and there would be zero impurities (water spots) on the car.
California is very dry part of the year. We get so much fine
sand blowing through that caring for your car is a heartbreak.
It's all dusty after a few hours. I just used some black spray
wax on my wife's car (the detailer did get all the 12 years of
water spots ground down, but there are like micro-cracks with
white primer hints). IMHO kind of low on pigment, but it did help.
An hour later I came out to check, and it had a fresh coat of that
Sahara wind-blown grit. Damn.
I think it's worth it. It's a pricey up front investment, but it's a huge time saver, saves you from having to touch your car, and it really works. I was shocked at how I had zero spots on my car even after leaving it in the sun. It's almost like magic.I really just wish the DI water systems were cheaper, then we could let the car air dry and there would be zero impurities (water spots) on the car.
So, @Jefsla you actually have a resin deionizer?
Before spending on a deionizer, maybe we try it first?
But then distilled water is certainly even cleaner.
You can usually find it at discount for like $0.50/gal.
If we could just get it supercheap in bulk ...
A pump sprayer works great for distilled water & ONR,
I got the corrosive-resistant model just to be sure.
So the recipe would be:
1) blow off or dust off the dirt overcoat, 2) spray on
ONR at 1/256, 3) gently drag ONR soaked micro-
fiber wiping towels on surface and 4) just let it air dry?
I suspect the plain ONR might work best for this, the
ONRW kinda like to be buffed ;-)
For the old style soap and rinse method, one could
use a 3 gal model full of distilled water instead.
Hey, maybe that's the way to do the initial pre-soak for
ONR methods? I just use the hose if I can't dust it off,
and distilled water would be far far better.
Sounds like a bit of overkill for a 40k dollar daily driver.
Not to be a jerk, but as an engineer with a bit
of chemistry background, I gotta say that H2O
distillation removes everything that isn't volatile.
By definition that means zero dissolved solids.
Trace volatile stuff? if it's volatile enough to pass
through distillation, then it's volatile enough to
immediately evaporate off the car.
Now the A+ convenience of DI water on tap cannot
be denied. Do you know how much DI H2O you
run through in gallons for a typical wash, @Jefsla ?
You’re not being a jerk at all. Maybe it was the water I bought from target, but it always left spots if I didn’t dry it well. The spots were no where near as bad as the tap, but there were still spots if I didn’t towel dry or blow dry.Not to be a jerk, but as an engineer with a bit
Ya, distillation is going to remove just about everything. In fact, a lot of DI system's will still leave trace levels, 1 to 2 ppm. If the DI system can work with a pressure washer then that's the huge benefit. Being able to just spray the car off with the DI system and a pressure washer would be nice compared to hand rinsing the car with just a couple buckets of distilled water.
'@Fossil Fool I'd love to just drive through, but if it's "no touch" they usually hose it
pretty brutally, if it's "contact sports" they scratch it up, and both technologies have
rising admission price, and they're a couple miles away.
If we could do it fast at home, isn't it kind of like owning our own arcade game?
Now @Jefsla if you'd just see the light and convert,
to ONR, or ONR+wax,
that DI system of yours could kick the llama's ass.
If I had one, I'd try
1) plain water pressure pre-wash, pick off nasties w/ favorite solvents, then
2) wash and soak panels or whole car with DI, to leave only clean water, then
3) spray on ONR solution ~ 1/100 in DI water. Normally you use 1/256, but with
the DI pass leaving that clean water on the surfaces, that would end up diluting
the total ONR about to that. Then as you watch the dirt nuking into the solution
4) soak microfibers with ONR solution, and do the customary ONR wiping, folding
and turning the cloth as dirt is pulled off the car into the microfiber cloths. If you've
never used ONR, hallelujah, you can't imagine how well that works. Then
5) Normally you'd dry with say waffle-weave microfiber drying towel(s)
but if the @Jefsla DI schtick works, you might not have to, and that would be
... NO step 5! how awesome! You wanna try it?
Me, I'm still struggling with gallon jugs 'o distilled water, but I have a feeling.
hallelujah, that between all of us here, we'll soon totally figure it out!
Understandable, it's certainly not a setup for everyone. I'm still optimizing it. I keep my PW permanently connected to power, and have a quick connect system so I can be up and running in 1-2 minutes. The DI bypass is right on the unit, so with a flip off two knobs I can switch between DI water and tap water.It takes me 15 minutes just to setup and put away my pressure washer (unwinding/winding connecting hoses, power, etc). Not to mention dwell time and ??? I use ONRWW weekly to clean a dusty, driven car. No pressure washer, just 1 gallon of ONRWW and several microfiber towels that are frequently folded and discarded (single bucket, never contaminated). While fairly quick, I have to skip the wheels and interior completely to approach 15 minutes!
