Make sure you call 3 different people and then pick the answer you like the best.
Okay, you got me there.
Thanks Greg! Is that Ellensburg or Detroit Lake?
It's Detroit Lake, OR. Right next to the existing AV charger, across the street from the grocery store...Thanks Greg! Is that Ellensburg or Detroit Lake?
Probably well known to others, but apparently the Eugene SC is only 90kwh. I used it twice over the weekend and both times it peaked out charging at 89kwh. A little disappointing some brand new SCs are only 90kwh.
That's weird, the tech I talked to when it first went up said it was 120! He even let me peak inside and there were 12 chargers in it. I wonder if it's a software thing? My understanding is that both the SC and the Model S need to have the appropriate firmware in order to take advantage of 120. So maybe the hardware is there but not the software? It's odd that the new SC aren't simply 120 from the start.
I'm on 5.8, so that's the newest software. I was the only car there and I was at 40 miles of range the first time, so if being that low can't get over 89kwh I'm not sure what would
Hmmm, it makes total sense that you should be getting 120 if it's available given your SoC and software version. I wonder if the SC firmware needs to be upgraded?
As mentioned elsewhere - I have gotten 102kW in my S60 and saw another owner get 117kW in his 85 at Woodburn.I'll second ckessel's experience. I have not seen better than 80 kW on either of the Oregon supercharges on my car, pre and post version 5.8.
