OK, so I decided I would take a look at this myself just to see if I found any holes. However, the purported documentation says nothing like what some have relayed.
First, the exclusion section is pretty standard and doesn't exclude anything of consequence:
The battery (already covered by 8 year)
Repairs or alterations not performed by Tesla
Failure to take your Tesla in when the defect is noticed
Negligence (and a big long sprawl about what that means).
Accidents (and another big long sprawl)
Tires and wheels
Tesla used for towing
If the odometer is inaccurate such that the true mileage can't be determined
Salvage Teslas
Incorrect towing
Damaging a vehicle further by continuing to operate it after its been damaged.
Corrosion of paint.
Tampering
Damage to a covered part caused by a non covered part(OK that one is a little weird)
Squeaks , rattles, etc.
Maintenance/Parts
And here's the big actual list Other Parts:
Bright metal, sheet metal, bumpers, ornamentation moldings, carpet, upholstery, paint, shock
absorbers, battery, battery cables, lenses, light bulbs, sealed beams, glass (e.g., windshield),
wheels, interior trim, body seals and gaskets (e.g., weather stripping); and
o Removable soft tops, removable hard tops, glass, plastic, framing, cables, or seals;
Notice the part about soft tops. This was also written for the roadster.
As far as I can tell, this ESA covers pretty much everything.
Some of those parts listed in the Other Parts section would be covered by the original warranty but all the rest of the items excluded already wouldn't be covered.
Next, it says:
The Owner’s Manual includes specific recommendations regarding the use, operations, and maintenanceof the Vehicle. To maintain the validity of this Vehicle ESA, You must follow correct operationsprocedures and have Your Vehicle serviced as recommended by Tesla. "
Except the owners manual has NO recommended services or service intervals. None. Someone please point it out to me because I looked at every page. The only mention of the 12 month 12,500 service is on page 41 under the warranty section:
- In addition to the above exclusions and limitations, this New Vehicle Limited Warranty does notcover any of the following:
- Maintenance services, including, but not limited to, the following:
- Standard 12 month or 12,500 mile service and diagnostics checks;
- Wheel alignment or balancing;
- Appearance care (such as cleaning and polishing); and
- Expendable maintenance items (such as wiper blades/inserts, brake pads/linings, filters,etc.).
But this is *not* under a recommended or required service / maintenance section. It's in the warranty exclusion section. It says these regular services aren't covered by the warranty. But it doesn't say those services are required.
In order for it to be required, it must be listed in a section specifying exactly what service items are required along with the mileage and or intervals.
All the ESA says is that you must follow the recommendations in the owners manual and there are none.
There should be at least brake fluid intervals and battery coolant intervals but I didn't even find those.
Now maybe my eyes are getting old. Actually I just about need reading glasses. Maybe they changed the documentation recently. Maybe I just missed it and it's buried somewhere but it's not supposed to be buried or hard to find. So somebody please help me out and tell me where I missed it.
