Have to agree with this. I normally charge my P85 to 90% (with a small handful of 100% charges before long trips), and have lost only 2 rated miles at 90% charge in over 3 years. I find the new charging UI does make it more difficult to set the charging level accurately, but the difference between charging to 85% and 90% is pretty negligible.
If you are going for "ideal" battery health, then you would set the slider to a point that will cause the average state to fluctuate around 50%. For example, if you use up 20% of your range daily, then you'd set the slider at 60%, drive until you reach 40%, and charge back to 60% again. If you don't drive much, or it's going to sit for a few days, then put the slider at 50%.
But most of the time, you want "practical" battery health. That usually means charging more than 60% full so you have enough range to actually drive somewhere on a moment's notice, and letting the BMS worry about the details.
