Why are there two different functions (Park and emergency brake) and ways to engage them if they are the exact same thing?
Because 49 CFR § 571.135 requires, by law, a control for the parking brake that is independent of other controls. You may wish to actuate the parking brake while under motion, while "park" is only available when at zero speed.
Why is one able to be engaged at high speeds (emergency brake) but the other requires the car to be under approximately 1MPH (Park) if they are the exact same thing?
Park is not the same thing- it also disables the drivetrain. While parking brake only changes the brake system.
Why is one called Park and the other called SuperPark in CAN bus logs?
Because the can bus log names were made up by someone that doesn't work for Tesla. The CAN bus does not label itself. It's just something Jwardell came up with to try and define the difference between two sensor states in the CAN bus, but we don't know for sure. SuperPark is not a Tesla term in any way, shape, or form.
Why did a Model X roll back on a boat launch (incline) while towing a 5,000lbs boat in Park but, after engaging the emergency brake, this Model X did not move?
Because this car first went into park, and then the parking brake was used. This is TWO applications of the system. Just because it happened doesn't mean it's a purposeful part of the design that can be relied upon.
We will never know unless you go back and try the test I listed- which is to not do PARK and then BRAKE. But instead to put it in Neutral and go straight to BRAKE. Also, you must make sure you do all of this without your foot on the brake pedal at all. If it is on the pedal, you're helping the parking brake engage in some Teslas that use a shared caliper.
Now a question for you:
If activating the Parking Brake is purposefully designed to provide more holding force than just putting the car in park, why does Tesla not document this in any way in any of their manuals? Rathe than saying "when on a steep hill, use the parking brakes for extra holding power" what they actually say is "don't rely on them."
It's actually hilarious that people have been in this thread discussing how it uses the hydraulics, etc, when the manual literally tells you this isn't true.
What is also interesting is that Tesla treats activation via the stalk and the touchscreen differently. Using the touchscreen actively puts you in neutral, telling us that Tesla doesn't expect you to use the "parking brake" to walk away from the car at all, since they don't allow a car to be in neutral with nobody in the seat.
