@fiksegts On your video, the P100D showed a power warning during the vbox test. Any ideas what the car was complaining about?
That's what I was wondering as well seems the car might be even faster according to the video and those warning / power limiting triangles
They have been doing that every few months since introduction of Dual Motors....can anyone say P85D w/ INSANE mode? Pre-AP cars had YEARS of being relevant, but now you only get a couple of months to be king of the mountain, innovation is the only thing that matters to TM.
A couple of interesting observations from the video:
1) The center console comes with rear cup holder and rear USB ports, hope it is not a P100D special
2) At the end of video, the guy sat in a car with pano roof, and talked about "this car", while it was clearly stated earlier in the video that "this car" does not have pano roof.
good question....
Tesla batteries are "overcharged" when new so they all show more range than specified.
Taking a second look at this chart I'd guess that motor cooling is the limiting factor not battery cooling, the batteries have a ton of thermal mass relative to the motors and the area under the two curves prior to fade looks about the same when adjusted for the fact that heating is proportional to the square of current.I added a graph of the P100DL vs P90DL v3 (the TRC car)
Even if you don't have them aligned exactly, the slope on the p90d curve is steeper than on the p100d.It's quite hard to line up the data points between runs due to the sampling rate...
Question, how does the P100DL 'only' get a 10.7s 1/4 time when the Tesla Racing Channels P90DL does a 10.8s. Isn't it 567kwh vs ~512kwh?
In the video he first says 10.8. That's probably the rounded version the vbox displays. The saved data has more resolution, but It's probably still close to 10.8. If you look at the superimposed power curves he posted earlier, the max power is only available briefly before it starts to get pulled back. It also looks like the p90d's power comes on more quickly at the beginning of the run. They may be bringing the power in more slowly so that that they can keep it at max longer before having to start pulling it back.Question, how does the P100DL 'only' get a 10.7s 1/4 time when the Tesla Racing Channels P90DL does a 10.8s. Isn't it 567kwh vs ~512kwh?
