St Charles
Tesla, not TSLA!
I've seen this on my car as well. I suspect it's a pre warning light regarding heat in either the battery or motor.
Yes how did you get this screen to come up? Some people with recent software upgrades found that this screen was up on their car but disappeared and wan't selectable again.Great insights! How did you get that screen to show up on the screen? a hack?
The limit is very often the motors if the battery is not very hot from supercharging or using battery max power.
To be more specific its the stator that does overheat. And that is the reason dual motor can be driven fast for longer than the rwd model S before power limit.
Here is from 100 kph to 250 kph on a P85D. (62mph to 155mph)
Battery temp did only raise 4 degrees Celsius from 30 to 34 degrees. But Stator did go from 48 to 115 degrees in no time and I got power limit to only 200 kW.
In my opinion 27 horsepower loss/gain from car to car is drastic. Would you agree?Where's the drastic difference?
Yes, 581 was pretty sweet in the loaner! Mine can only manage 561 at this point. Not sure what you mean by “He only got 100kWh...”581 kWh!!!!
He only got 100kWh ...
People with the least knowledge, cry the loudest...
I am simply reading the screen 581kW vs 561kW. How am I using the wiring units? Please explain?You're using the wrong units.
Got it. Thank you for your explantion! That’s been more informative than anyone at Tesla! Thanks again! It’s a bit disappointing as it does effect the Performance times that I’ve tested with the VBOX on both cars.20x1.341 = 27 hp. But if you want hp at the motor then you need to deduct about 10% which is 24.
Regardless, it's about a 3.5% difference which is less than typical ICE variation at that power level.
Cell binning will more than account for the difference. I'm surprised it isn't more as once you account for mileage and other factors like temperature the difference could have easily been far greater and it would still be normal.
If you've done a number of Ludicrus Plus launches with your P100D, the equipment has probably degraded. That much current is hard on the parts.
