Todd Burch
14-Year Member
The regen case doesn't apply for the Model S, since all regen is tied to the throttle (the correct approach IMHO).
Hopefully with the Model D they can capture more brsking force and thus regen than would be desirable to trigger with only the throttle. That is it wouldn't be desirable for the car to come to a screeching halt when lifting off the accel pedal. That additional regen braking force is better triggered by the brake pedal.The regen case doesn't apply for the Model S, since all regen is tied to the throttle (the correct approach IMHO).
Considering that we've established that the battery, and not the motor or the wheels, is the limiting factor, and that the battery pack on the D is unlikely to be able to accept charge at any faster rate than the non-D. What makes you come to this conclusion?Hopefully with the Model D they can capture more brsking force and thus regen than would be desirable to trigger with only the throttle. That is it wouldn't be desirable for the car to come to a screeching halt when lifting off the accel pedal. That additional regen braking force is better triggered by the brake pedal.
Superchargers only charge the car at 120kW. the other 10kW is to improve rates for a second car on the same charger.Superchargers charge at 135kw, so why wouldn't it be able to take 135kw of regen braking?
That is true - but with the nifty new EMBS you could also apply more regen with the brake pedal and get the best of both worlds while blending regen and friction brakes seamlessly.If you did allow 120kW regen, you'd only have it for the bottom 10-20% of the battery, which means that your regen would be unpredictable, you'd never know how much braking force you get when you initiate regen, that's a very poor driving experience.
The question is, can you really do "seamless", and is it worth the increased complexity for the very small gain (only providing a gain at very low states of charge)That is true - but with the nifty new EMBS you could also apply more regen with the brake pedal and get the best of both worlds while blending regen and friction brakes seamlessly.
At that point you're best to avoid any changes in speed that you possibly can to maximize efficiency (coast as much as possible, limit braking and acceleration)On the flipside, if you are down to 10% range, you might be willing to trade a somewhat less seamless experience in order to maybe get a couple more miles to a charging station?
Superchargers charge at the 120kW rate only when the battery is near empty, by half full the charge has tapered down to about 60kW, and by 3/4 full the charge is down to about 20kW or so. So the 60kW regen is already MORE than a supercharger anywhere above half charge on the battery.
Why are people pushing for regen to be moved to the brakes? Keeping regen on the accelerator pedal is, IMHO, one of the best "driving feeling" decisions Tesla's made. Not just because it avoids the complexity of trying to keep natural braking feel, but because it lets you control the car in most driving situations without moving your foot very much.
I guess we are all used to ICE cars where you have one pedal to go and another one to stop.
It really does make more sense to have a single pedal to control stopping and starting.
I've driven hydraulic snowcats where there is a single control for forward, reverse and turning... it's really quite easy to use.
I like to tell people who know how to drive a standard transmission, that the accelerator is like always driving in 2nd gear. They get it immediately.
CW,
I like that one. Consider is stolen (if you do not mind)
Interesting theory. I don't buy it for a second, but it's interesting. I'd love to be proven wrong, however I highly doubt we'll see the D variants having double the regen of the normal ones.
