Normal battery degradation doesn't affect performance. Performance is a combination of peak voltage, nominal voltage and output current. Normal battery degradation reduces the charge capacity for a battery and after a while peak voltage, but not the nominal voltage and current output.my battery has lost 13% and it is still within 0.01 seconds on a 0-60 and 1/8 mile time. So I’m not sure if a higher % loss makes a difference, but mine has not, at all.
When enough degradation has happened maximum current output will be affected, and finally nominal voltage.
According to the subsystem specification the nominal voltage is 320V and max currents are:
980 motor (RWD, Performance, Stealth) - 800A, max power 202kW
990 motor ((most) LR) - 600A, max power 180kW
Front motor - 600A, max power 137kW
Of course, they don't output all of that at the same time. The max effect is at a certain RPM, which is different for all 3 motor types, but just to give an example we could say max simultaneous power of 320kW on the Performance (it isn't) makes 320V nominal voltage and a 1000A current (which isn't correct).
However, that's only theoretical numbers from the subsystem specification, the battery specification (according to unconfirmed sources I've read, so grain of salt, et.al) says 350V nominal voltage and peak output current at 1200A, a theoretical nominal power that would amount to 420kW. So given these nominal values you'd be able to max out the motor until the battery has degraded to ~24% of it's maximum nominal output.
Of course, this is only a simplification I made, in reality you the peak voltage (400V) to achieve the max power of the motors, which requires a high state of charge and healthy battery modules. However, unless you're using the car for drag-racing all the time then your TM3P/stealth will likely maintain it's performance for several years before you start seeing a occasional drops in 0-60 times. Especially considering that the battery consists of several modules which can be replaced for a reasonably-ish amount.
