Jeff Hudson
Lovin the Tesla Life
For calculation purposes who can tell me how many usable kW's are in the Model 3 Performance battery.
So I plan to try traversing the I-65 Interstate between the Athens, AL Supercharger and stretching the mileage to the Greenville, AL Supercharger 223 miles away without stopping at the inconvenient Birmingham Supercharger. What does the community think I should hold my max speed under? The speed limit varies between 60 mph and 70 mph which is typical for an Interstate highway.It's up for debate, but about 75kWh. Realistically, you can go about 6 miles after it reads zero - source: Elon Musk - (not at very high freeway speeds), so there may be as many as 77kWh available. And if you look at the calculations online and numbers of cells in the battery, it works out to something like 78kWh.
Thanks for that tip about using the energy screen. Does skipping a Supercharger throw off the calculated prediction? And yes I do have the stock 20" Performance wheels with the Michelin Pilot Sport 4S 235/35ZR20 (92Y) XL tires.Look at the Trip planner on the energy screen second tab; if you plug in a destination in the nav first, it will provide you with real time updates of your expected remaining charge level at your destination. If it goes below zero, slow down!
What do you mean by this? Can you describe what you're talking about in more detail because I don't understand the question?Thanks for that tip about using the energy screen. Does skipping a Supercharger throw off the calculated prediction?
My understanding of Tesla's GPS routing software is that it is always aware of the locations of their Superchargers. I suppose I was thinking the energy graph may not be as well integrated with deciphering a planned GPS route without stopping at an available Supercharger.What do you mean by this? Can you describe what you're talking about in more detail because I don't understand the question?
If for example you drive 20 miles and it has dropped from 10% to 8% and you have a 150 miles to go you need to be slowing down a bit now, or get on CC with a 4 or 5 follow distance from a vehicle in front of you.
Ah. No, it is periodically redoing the calculations while you are on route. Not sure of the exact frequency but about every minute, or maybe less. So it can suddenly on route change its recommendation of whether or not to skip SC, or it'll even send you sideways to a closer SC if there isn't one between you and your intended destination SC and it estimates you won't make it directly to the destination SC without a stopover.My understanding of Tesla's GPS routing software is that it is always aware of the locations of their Superchargers. I suppose I was thinking the energy graph may not be as well integrated with deciphering a planned GPS route without stopping at an available Supercharger.
All I can say is I use 100+ more kwh on my model 3 p than my wife's rwd one
I'm impressed! But I don't think you mean that (at least not without specifying a distance). Maybe you meant to convey you use 100 more wh/mile?
When we drive our LR RWD and Stealth Performance in a similar manner the difference is less than half of that. The Aero wheels and Michelin Primacy tires really do make a big difference.
It tries but if it is off due to outside temp bias it has, or such, this is the way you can compensate for that. Doing it this way you can dial in within +/- 1% or so over a 200 mile leg. That's kinda on the edge to travel like that, and I understand fully not everyone wants to go there, but it works.Really? I have no idea, but I assumed it would extrapolate from your past 20 miles of driving behavior, all the way to your destination...so if it updated to 8% it would kind of stay there, if you kept the same driving behavior. The one time this was relevant to me and I used it, I kind of felt like it worked that way. But it was just one time...no real experience.
Story checks out. It's quite easy to get ~200Wh/mi in the LR RWD and quite easy to get ~300Wh/mi with the P3D+.
I fully expect that even with a full charge the Tesla GPS routing software will tell me to stop in Birmingham since the full distance will drop the reserve below some preprogrammed GPS battery "safe arrival" level. If so, this means I will have to willfully skip Birmingham despite the Tesla GPS insistence I stop to charge which is not what I want to do because the Supercharger lot is a pay-to-park and a real time-suck to get into and out of.So plugging in the destination in advance (without your full charge) and seeing what it tells you as a test, might not give you the same results as it would when you fully charge your battery to 100% just before you leave.
