ChrisJ
Does your cost modeling take into account NBCs under NEM2? Because unless you consider NEM2 NBCs, or you have Powerwalls for time-shifting, then under NEM your usage pattern is immaterial to the economically optimal generation choice. The two are decoupled.
I'm not using Powerwalls right now. If my usage pattern is immaterial, then maybe my hour by hour model is flawed from the start. It does not factor in Non-bypassable charges either but it could if I could figure it out. Any pointers? On the rate schedules breakdown I couldn't see anything beyond that I'm not except from it.
In the long run, adding West facing solar is likely to be better for society in terms of balancing the grid. It's not clear to me that the extra 680 kWh/year the South facing option would generate will displace CO2 generating production.
Cheers, Wayne
I just modified my model to break out the production after 4PM , and you're right, West produces almost 2X during that time (490 kWh vs 990 kWh). But overall the system West facing will not generate enough to cover all the kWh's I use in a year. I was hoping to get to zero. Maybe I should add a few more panels
If you have any pointers how to add in NBCs then that would help a lot.
Cheers
