Gen II Prius 2004-2009 is only 4.9" ground clearance
Gen III Prius 2010-2015 is only 5.5" ground clearance
Gen IV Prius 2016 - ???? is only 5.7" ground clearance
Nissan Leaf (2011 to 2016) are all 6.3" ground clearance
Model S Active suspension in highway mode is 5.21" ground clearance
Model S Active suspension in normal mode is 6" ground clearance
Model S Active suspension in high 1 (less than 20 mph, aka 19 or lower) is 6.9" ground clearance
Model S Active suspension in high 2 (less than 11 mph, aka 10 or lower) is 7.3" ground clearance
The suspension will also self-level the car. For example if you load a lot of weight in the trunk the vehicle will remain level (edit: apparently this happens when you put the car in park, might have to shift out of an into gear to activate?
