Well damn. Seems unfinished for a 60k car.
I get it for a 25k kia forte .. but come on
Same for me. I took delivery late February 2022.
Performance with upgraded brakes have an approximately 3mm thinner rotor hat, so the wheels sit further inboard by 3mm. This also exposes a wider 70.1mm hub flange, which is why we all ask if certain wheels are bored to accommodate the lip.is there a difference between LR and Performance in offset in the hubs?
does one or the other sit further in/out between the two models? if so which one by how many MM?
This thread explains it
Model 3 Non-performance - wheel hub lip length
Hello, Could any one tell me the length of the hub lip of Model 3 non performance? (Not diameter) I assume it is about 8mm, am I right? TIAteslamotorsclub.com
That has more to do with performance handling aspect and lesser priority on range than anything else.Not entirely true. The wheels on the performance have a 35mm offset vs 40mm on the LR.…which more than makes up for any difference in rotor thickness.
I wasn’t talking about any performance aspects. I was simply referring to your comment that “Performance with upgraded brakes have an approximately 3mm thinner rotor hat, so the wheels sit further INBOARD by 3mm”.That has more to do with performance handling aspect and lesser priority on range than anything else.
From a mechanical and fitment stand point, the offset difference is only 3mm. As long as you take those 3mm into account for your wheels, they'll fit virtually the same.
That guy was asking about difference in the hubs, and we all know they're the same hubs. It's the rotor that makes the mechanical difference.
Again. My comment has to do with same wheel offset on LR vs Performance hubs. No other difference save for the 3mm thinner rotor hat. My response was to the question pertaining to hub differences.I wasn’t talking about any performance aspects. I was simply referring to your comment that “Performance with upgraded brakes have an approximately 3mm thinner rotor hat, so the wheels sit further INBOARD by 3mm”.
Since the stock Performance wheels have a 35mm offset (vs 40mm)they will actually sit 2mm further OUTBOARD and not inboard. In the end the few mm doesn’t mean much and agree they’re virtually the same. I based my custom offsets off the stock 35mm….so in a way I did take into account that 3mm lol.
That's all. You decided to chime in that LR and Perf wheels have different offsets. I pointed out that's a package feature Tesla decided on based on handling and aero priorities being different on LR and Perf trims.
Hubs are the same.
I'll leave it at that.
Same for me. I put in a service request. Does anyone have pics of with one actually in on a 2022? I want something to use as evidenceSame for me. I took delivery late February 2022.
My 2018 is missing it. But then again in 2018 model 3’s were missing clips in the fender liners, cf spoilers and badges lol. I don’t even notice it. In fact I just noticed my left led wasn’t lit lol. Tech must have forgot to plug it back in when I just had it serviced.
I have this warranty work scheduled, I wonder if this is related to the issue you encountered:I’m just out of warranty so decided to try the squeak fix for the upper control arm joint. Squeak went away as soon as I started rotating the joint.
My 2021 M3P has it.My 2018 is missing it. But then again in 2018 model 3’s were missing clips in the fender liners, cf spoilers and badges lol. I don’t even notice it. In fact I just noticed my left led wasn’t lit lol. Tech must have forgot to plug it back in when I just had it serviced.
Description Of Work:Concern: Reseal Front Upper Control Arm Ball JointsCorrection: Reseal Area Around Both Front Upper Control Arm Ball Joints With Urethane(Model 3)Parts Replaced or AddedPRIMER, BETAPRIME,10ML(1059658-00-A)SEALANT, BETASEALEXPRESS/EXPRESS +(1048645-00-A)Pay Type: Basic Vehicle Limited Warranty
My 2021 M3P has it.View attachment 813752
