spaceballs
wk057 this is a Awesome thread!
BTW there are gid tie inverters that work at ~400v that might work so you shouldn't have to break apart the existing pack. Also there are cheap china grid tie inverters that you can put in series that would be capable of handing the ~400v, but you would have to build a way to disconnect them when the battery pack got too low.
Saw a few chats on the battery balancing, is anything like the Roadster battery balancing the BMB (which I've been fighting against for a few days, but won). There is a power darlington transistors connected to an surface mount bleed resistor ~40 ohms (1210 size I think), across every brick of cells.
Again great post!
Again great post!
