There's not much to speculate about.
LR and Plaid are18650 packs with redesigned modules for better cooling. I expect the LR/Plaid packs are identical, and within ~5% of the prior revision's 100kwh capacity based on range numbers.
The 4680’s will likely be packaged with the new structural battery pack. One would think that would require an entirely new chassis system. When the plaid+ comes out they could switch over the S and X to the new layout(likely given the late 2021 date). Would need another 30KWh of storage to get the 520 range, the 4680’s give way more power but I don’t think the storage goes up 30%(trying to remember battery day). Of course a pessimist could point out that they could put another stack of batteries in the back and loose 6” of trunk depth. Or split it between trunk and frunk(how many kWh will fit in the glove box?). Fun to speculate, we will know in less than a year, hopefully.
Because they said they were, and it’s the only obvious outcome.Why do you think they are still using 18650s? Why not the 2170 cell from the 3/Y? I'd think Tesla would want to move on and consolidate cell production as much as possible instead of supporting the production of 3 different cell sizes.
I wonder how the packaging will work when the platform will utilize cells of different heights.
Plaid+ is the only speculative bit, and it seems obvious to me that Plaid+ is (Plaid + 4680 pack). There's no other way to enable that range within roughly the same packaging.
To me it appears that the refresh brought the first of a two phase strategy for battery/structural revision.
Phase 1 is to significantly revise the battery pack structure and external fitment. This entails using the existing (and available) 18650 batteries within a newly designed housing (the promised structural battery pack). This required significant changes to the car's unibody structure to accommodate the new battery pack, and is primarily responsible for the 250# weight savings of the refreshed vehicle. The battery pack architecture will be available in a 4680 version which will be externally similar and which will (Phase 2) drop into the revised chassis.
Eh, that’s a no from me dawg.
I don’t think there’s anything to suggest the structural components of the car have changed at all. I think the external mounting points and vehicle/battery interface points haven’t changed whatsoever.
I think it’s simply a revised 18650 pack with an evolved module design and better cooling. It’s plausible there are less individual cells in the pack due to increased energy density. This seems like a far more likely explanation for the reduced weight than the more radical changes you’re suggesting.
I just don’t see any scenario where they fundamentally redesign the chassis, subframes, and structure while keeping overall exterior styling and dimensions essentially identical.
Time will tell.
Source? I don't think there's any indication whatsoever this is what's ending up in production cars now.Has anyone been paying attention to the media? During Sandy Munroe's interview with Ellon, Mr Musk said that future Model S and X would feature front and rear megacastings connected by a structural battery pack. Today, photos of the new Model S megacastings were leaked and are online. I think time has told...
I have to say, I don't think so either. I very much doubt if the mega castings will be ready for the Plaid+ later this year.Source? I don't think there's any indication whatsoever this is what's ending up in production cars now.
And on the topic of the refresh, batteries, and Sandys interview with Elon, Elon stated that the 12V battery will now be Li-ion instead of a AGM lead acid battery.
Right, but then you said “time told”, suggesting you’ve decided you were right based presumably on some sort of evidence.As I said earlier, time will tell
