Someone did a video where they removed the screen entirely.. For testing... Everything worked EAP, music, driving, cruise control etc. I used to worry about rebooting while driving but after seeing that I'm less worried.I dunno about frequent, but I get it periodically. Mostly when it's been in deep sleep for more than a day, but it has happened a few times when the car was just driven a couple of hours ago.
Bizarrely, the car still works sometimes even when the screen is black. I can flick the stalk to R or D and just start heading out. Screen eventually turns on while I'm driving. Since I can drive, it doesn't overly bother me.
I’ve not heard of this ever being fixed with a firmware update... though it’s what service kept telling me. A new CPU was the answer for me and many others. Prepare to lose all settings and memories! Only thing that will be retained is the odometer.I was hoping for a sw update fix but no luck.
Now I have to decide when the annoyance of the startups exceeds the annoyance of trying to convince service to replace the computer board along with the likely several hour long trips to service....
It makes little sense to see that hardware DOES fix it while we keep hearing about a coming software fix? Why does hardware fix it????The claim I have heard locally from a service tech is that the fix is coming in firmware 52. Not sure how long that will be but I think they're up to 50.7 right now.
I suppose you're right. Just seems odd, I guess. And nobody likes to continue hearing "just hold tight. This will eventually be fixed with software" when we already know they've fixed it... with hardware. Sure would be a great money savings if they could flash the fix!Can't say without inside info. But I can envision a situation where an older hardware revision has a particular bug that has been solved in later revisions, but is also fixable by a software change designed to not trigger the bug.
This happens all the time for me at least 50% of the time I enter the car over the entire 7,000+ miles I've had it and across all firmware versions. I thought this was normal? No way I would rob a bank with this car.I've had delayed 30+ seconds of black screen followed by "T" (looks like a reboot) twice while getting into the car on 50.6. This never happened before.
I use easy entry and run the seat all the way back and have the steering wheel all the way up. So I would have to manually adjust my steering wheel and seat first. I don't think my car has ever lost more than 1 mile range per day and I've went a couple days unplugged where it only lost 1 mile Of course I get to wait on the black screen then Tesla logo. Given how several people complain about vampire drain I think I'll keep everything the way it is.99% of the time for me, the screen turns on as soon as the door opens so you might want to get that checked out. However even if the screen is off you can put it in reverse/drive and drive it, so still great for bank robberies.
Well I updated to 50.6 8 days ago and now my car is using 5 or so miles a day. But hey my screen is no longer black when I open my door.Wait is there an option to have my car fully off like that? I lose anywhere from 5-15 miles of vampire drain a day, on extended days when I'm not driving or traveling, I wouldn't mind turning it off to stop the drain. I never knew I could.
I’m on 50.6 and I get reboot 50% of the time when I start car.Well I updated to 50.6 8 days ago and now my car is using 5 or so miles a day. But hey my screen is no longer black when I open my door.
Then you do not have the same problem.On the newer firmware, I haven't had this happen since the single time in October.
