No it's 200% real time. Elvis is witness.
Perhaps on the main course tonight is obfuscation disguised by buffoonery?
6:40 wouldn't even beat Volkwagen's EV. Pathetic!
The trap speed is 125mph which is basically the same as Top Gear's results (123mph). Trap speed is much more repeatable than ET and is correlated much more closely with horsepower and much less with traction. The track Top Gear used probably had less traction than a real drag strip.Better yet a slip time from a Dragway. That's actually the gold standard not vbox. And while two tenths of a second doesn't sound like much at that speed it's almost 40 feet. And to really rub it in the Porsche cost about ten thousand bucks less than the new Roadster will cost. And that's not even a contest.
They claim they did. I'm not sure why people are so confused. The Model S pulls crazy hard at low speeds so it needs lots of traction to get the best times.Yes and as several people have discussed they didn't have it in the max ludicrous launch mode.
I think Top Gear has hit their head a few too many times.
I can run 11.2s (the times they claim the Raven Model S ran) in my Pre-Raven P100D Model X.
I will be out tomorrow in my Raven Model S with Dragy device collecting my own times with video on surface roads.
BTW, the drag race shown against the Audi R8 V10+ in Dragtimes vid is my Model S with me as the driver. It ran 4 passes that night all in the 10.6 range.
Get a Taycan Turbo S and make the comparison on the same track at the same time at the same ambient temperature.
Are they using 1 foot rollout? That's 0.2 seconds.On a serious note, I can't imagine any relatively clean asphalt surface making the Model S drop to 11.2sec runs at 85% charge. They clearly are not doing something right.
I absolutely care!! I take pride in owning the quickest mass produced EV in the world. If Porsche (or anyone) makes something quicker than congrats to them. But if they don't make something quicker and someone reports that it is quicker it needs to be called out. And if Tesla no longer is the quickest than so be it. I will keep my Tesla but no longer claim to be quickest.
BTW, I'm 46yrs old.
I have a Vbox, it's an option. Not sure if it defaults to that or not.Vbox calculates in the 1 foot rollout.
Good point on the ambient temperature. Gotta make sure the DA is the same cause that can affect the turbo big time in the Porsche.
Jason
Here's a plot that illustrates what's going on:
Both the 911 Turbo S and the Model S have basically the same 1/4 mile time but the Tesla needs enough traction to pull 1.4G to achieve it. The 911 accelerates faster after 60mph so it has a higher trap speed but that's not enough to overcome the Model S advantage from 0-60. Now, on a road surface with a little bit less traction the 911 will be quicker in the 1/4 mile. There is no mystery or conspiracy!
Did my own testing on my 2019 Raven Model S Performance on surface street. Launch Mode used and full blown Ludicrous ++++ secret easter egg mode engaged.
96% SOC - 10.67 @ 124mph Max output 581.6kW
88% SOC - 10.7 @ 124mph Max Output 580.7kW
Thanks for your data.
I made an approximate distance calculation based on the acceleration numbers. I just used constant acceleration between the time points so it's not perfect, but it shows a difference in your and Top Gear's runs.
You appear to run a shorter distance, not 1/4 mile.
Just look at their Taycan time. They reach 1/4 mile in similar time than you, however their speed is a lot higher, over 130 mph and 0-60 is better than yours. That alone suggests you run a shorter distance.
1/4 mile is 402 meters.
For the Top Gear runs I estimated 397, 403 and 403 meters. For yours they are 383 and 382 meters.
One more question, are you on 21" rims?
For sure.Or just wait until someone takes the Taycan to an actual drag strip and I bet we'll see that it's quicker than the Top Gear time.
Their times for the P3D and BMW M3 are also slower. I bet they don't use 1 foot rollout and their track isn't all that sticky.
P3D 11.9 @112.6
M3 12.6 @119.1 (Major RWD traction penalty!)
