I'm interested in maximising range. There's a rare round trip I will need to make which will be border line do-able without a charging stop. The quoted range for the 2021 UK model 3 is 360 miles. On a recent shorter trip in 40 degree F temps I calculated it out to be not much more than 200 miles which I found disappointing. I know the range will be better in the summer (it rarely gets into the 80s in the UK) but I'm wondering how much higher that 200 range would have been had I preconditioned via the wall before the trip.
I agree no point preconditioning for any other reason than maximizing range.
When (In the US) the EPA does range tests they test every car under the same conditions. It is also a combination of City/Highway. In November in my Model Y (326 mile range) with an outside temperature of 37 degrees Fahrenheit, Climate Control set to 71 degrees Fahrenheit with an average speed of approx. 72 mph on a 600 mile trip I was able to go 200 miles from Lexington, Ky 90% (Dsoc) to Worthington, Oh 19% (Asoc). That is a expected range of 280 miles. That is an 88% efficiency at that speed and temperature.Not anywhere close to 360 miles. Even in the summer time, to get 360 miles you'll probably have to drive 55 miles per hour the whole way and have no headwind and aero wheels and no passengers, etc, etc.
Thank you.. unfortunately it will cost me around 4-5k to get an outlet installed (level 2) and there’s isn’t a 110v outlet (designated parking spots) I’m trying to figure out if it’s worth the money and hassle (need to get permits + condo board approval + lawyer fees) too many red tapes in Toronto. I also don’t drive much and keep the battery at 55-65% at all time and works from home remotely (will continue post pandemic) don’t want to ruin the battery by not preconditioning it but is it true that it let me use certain portion of the battery while it’s cold and once I start driving and as the battery heats up it gives me back my regen plus the other portion of the battery ?It depends on your charge state and the distance driving. Preconditioning the battery regardless of the temperature will ensure that you you burn the lowest Wh/mile and have a longer range. The Snowflake means the battery is really cold, like brrrr... Preconditioning also helps the life of the battery and if the battery is cold you will get very little regen braking. Schedule the departure time and the car will figure out when to start the preconditioning. Do you not even have a 120 volt outlet in the garage that you can use. At 120 volts you can old draw 1,800 watts through a standard 120 volt outlet (20A) which is 1.8 Kilowatts. Where I live I pay about $0.12/Kwh equals about $0.216/hour of charging. There is now a Charge history in the car which will tell you each night how much power is used. In the US garages must have 120 volt outlets just to meet code even before EV's. You do not have to go to the garage, you can Schedule a departure time to have the car preconditioned.
One thing several of my friends in condos have done is negotiate switching parking spots so you are close to a 120V outlet ..though you might run foul of the resident association for who foots the power bills.Thank you.. unfortunately it will cost me around 4-5k to get an outlet installed (level 2) and there’s isn’t a 110v outlet (designated parking spots)
As others have mentioned, preheating is primarily aimed at occupant comfort. If you have a longer trip and preheat you are basically using power from the wall and not from the battery. If you look at a 30 mile trip in winter that might consume 10 kWh of battery if the car is cold. Now if you preheat that same car it might consume 11kWh total but 3 kWh came from the wall. So at the end of your trip the cars battery will have consumed only 8 kWh instead of 10 kWh.
Strictly from an energy standpoint preheating consumes more energy but leaves more energy in your battery. I believe this would also cycle the battery LESS than if you didn't preheat. In the grand scheme of things I think this is less than anything measureable on the batteries life. Again going back to occupant comfort.
The time it is beneficial (beside comfort) is if your going on a long trip, essentially adding 3kWh to you pack size, only becasue you consume it from the wall rather than from the battery once your moving down the road.
I would bet money that preconditioning before driving always uses more electricity than just letting the car warm up as it drives.Please help a Tesla noob here.. 2021 SR+ and I live in a condo with no charger or internet (car parked in basement level 4. Good news I’m yet to see theand I live in Toronto even when it’s -1 C outside the car park seems to be around 10-11C. Question do I need to precondition before I take the car out? I can’t remotely control it via the app and have to take the elevator down 20 stories to turn the cabin heat on? Can I just turn the heat on for 5mins before I drive? Is there an ideal time? My friend don’t worry abt preconditioning since driving the car heats up the battery too and the only perk is I’ll have regen and Tesla battery management system is pretty good compared to most other EVs..
You can put an ammeter on it. If you are plugged in but not charging you can see what the car is drawing on the display.When (In the US) the EPA does range tests they test every car under the same conditions. It is also a combination of City/Highway. In November in my Model Y (326 mile range) with an outside temperature of 37 degrees Fahrenheit, Climate Control set to 71 degrees Fahrenheit with an average speed of approx. 72 mph on a 600 mile trip I was able to go 200 miles from Lexington, Ky 90% (Dsoc) to Worthington, Oh 19% (Asoc). That is a expected range of 280 miles. That is an 88% efficiency at that speed and temperature.
Remember that the new Model 3 and the Model Ys are using the Octavalve Heat Pump. I find that if the car is pre-conditioned prior to departure the heat pump makes no more difference than the air conditioner.
I would like to see someone put an Amp meter on the heat pump and measure the current draw at different winter outside ambient air temperatures for heat and then in the summer for different outside ambient air temperatures for cooling...
Thank you this is helpful.. I’m going to stop stressing about preconditioningCarl, it doesn't hurt the car at all to not be pre-conditioned, the car won't let you do things to the battery to damage it, it will just reduce power if it is really cold and have little to no regen. Last winter our car would sit outside for 12+ hours at -15F or -25C and the car works fine, but no regen at all at those temps and it does limit the acceleration power as well. I have "scan my Tesla" so I can see once I start driving it when it's that cold it does actively heat the battery, but again the car will do what it does, just don't expect regen or sub 5 sec 0-60![]()
The biggest advantage I see for pre-heating is if you have a longer trip that is pushing the full range of the car because it will use additional power warming up the battery (and cabin) while you are driving, thus bringing your range down significantly, I have seen it as low as half my summer range in these conditions even with no snow covered roads. Basically if you can pre-heat with 6kwh from the grid to get the battery up to temp, that is 6kwh it doesn't have to pull from the battery once you are moving.
If I recall correctly if the pack get below 0F it does wake up and heat the pack
The second biggest advance is the comfort for those driving and or riding![]()
