ItsNotAboutTheMoney
Just a warning of tight supply. If you look at available v demand there wasn't much of a gap. That brings on some of the little-used capacity like oil speLooks like an overblown story as I have a friend in MA with solar and powerwall and the Utility did not need to pull power from his battery. Interestingly, the all time NEISO peak demand occurred in 2006 and efficiencies since then have kept the peak below that level. What’s more NEISO is anticipating that conversion to heat pumps for home heating in the winter is going to be the biggest driver/ issue of new load, more so than EV’s.
People who can't charge at home and who charge at work would already be charging during the day habitually and would be part of the regular demand. Their demand would be highest in winter.What about people who can't charge at home? They may charge at work (likely during the daytime) or wherever (e.g. public). At my work, we have better attendance Tuesdays thru Thursday and we have several dozen J1772 handles (each on a 40 amp circuit) + 10 Tesla wall connectors (5 100 amp feeds with a load sharing config of 2 WCs per 100 amp circuit). All of those are in use eventually at some point on each of those days.
But, our power consumption is really low compared to many Tesla Supercharger sites.
That's true now, except most of the vehicles are ICEVs so they are placing virtually no load on the grid ever. There will be a tiny load for short period of time when they pump gasoline.
Here in CA, when Flex Alert: energy conservation tips, save energy on high demand days in California are called on hot days (this is before we reach stage 1 or above emergency), assuming you're even aware of any of this, What is a Flex Alert? says what you should do. Someone DC FCing at even 50 kW blows the the conservation efforts of several houses with central AC or MANY houses without (raises hand).
You actually need to opt in to receive flex alerts and maybe your power company might notify you, if you're opted into something. Or, you might hear about it on TV or radio... most other folks I suspect are blissfully unaware
BTW, you can look at pages 1 and 3 of https://www.caiso.com/documents/grid-emergencies-history-report-1998-present.pdf for CA flex alert/alert and emergency history. Ignore years 2000 and 2001 when I was out of the state. Those were due to the Enron scandal.
There's a forecast of 6GW more of PV over the next 10 years, which marries up well with the shape of daytime charging.
But again, if there's significant sales of BEVs, I'd expect it skewed towards people who can charge at home and also to push the property market economics towards adding charging ar MDUs. (Especially with a shift to NACS, which could make deployment easier).
I mentioned the offset of home v road for the potential case of high travel on hot days. You shouldn't have both peak residential demand and peak vehicle demand.
