No, I'm saying that it's not directly comparing EV vs CS (which is why you don't find that in the paper as you note), but it is comparing EV vs the max performance of the car. So indirectly EV mode must perform as well if not better than CS. The two statements are not contradictory.
I find this line of argument unconvincing.
If the authors of the paper wanted to define "full-performance" in terms of the vehicles extended range performance (even via a level of indirection) they would have said that themselves.
The Volt diverges a bit above 70 in testing, but still close enough (0-60, top speed, 1/4 mile, the three specs most people care about, is pretty much the same) that GM doesn't have to quote different numbers for the two modes. The ELR diverges significantly in 0-60 mph and given GM says they accomplished this purely with software vs the Volt, it's pretty clear they have been artificially limiting the Volt's CS performance to match the EREV criteria.
Why would GM do that? Just so they can use the EREV term in their marketing material? I would think the marketing folks would much rather have marketed higher performance numbers if the engineers thought they could provide them at speeds down to 0-60.
You do know that the ELR is also marketed as an EREV?
Cadillac Begins Shipping ELRs to Dealerships
A more likely explanation is that GM was being more conservative in the engineering of the first Volt model. Originally they were going to use only 50% of the pack SOC range. The production car used 65%.
With more real world experience and testing they are now willing to push the hardware a bit harder. The ELR uses about 72% of the battery (about the same as the Ford Energi). The ELR also draws about 5-20% more power from the battery. And it drives the motors harder with additional power from the engine generator in CS mode.
With a little research this morning, I found a recent statement by a well-informed and credible GM service support engineer (WopOnTour at GM-Volt.com). He said the ELR has some improved electrical cabling and components that enable the higher performance -- it's not purely software.
See my point above. And given the Volt was still under development at the time, it's entirely possible that the Volt had changed to outside the boundaries of the definition by the time it was fully developed.
So now the Volt isn't an EREV either? I find this pretty convoluted and implausible. It's much more plausible that "full-performance" was meant to convey a generalized expectation that cars designed and marketed as EREV would be generally competitive in their performance in battery-only mode.
What I mean is that it doesn't make any sense in engineering terminology to define a car the way you have defined (dependent on "competitive" features vs other cars). Yes, when you engineer a car you want to make it more flexible. But what I mean is you can't be loose that way when coming up with an engineering term (as the paper was intended to do). It must be clear/consistent so you don't have ambiguity.
I think the paper could have been written with better clarity about what statements were normative specifications and where statements were explanatory or non-normative descriptions.
In some engineering cultures this is done explicitly using formatting conventions. I don't know what conventions are common in SAE papers.
What I'm asking is if the Energi would fit GM's definition under your interpretation of "full-performance", not about the default vs non-default issue (which is about your definition of EREV, which is clearly different than GM's). My point is that the cut-off point for EREV eligibility is very unclear using such a definition of "full-performance".
I think GM's definition and mine are the same because, after further parsing and reflection, I don't think "full-performance" is a normative (required) part of their definition of EREV in the SAE paper.
I'll assume you are asking my personal opinion of whether the Ford Energi "EV now" mode is "full-performance" from a non-normative perspective using GM's description of the meaning of that phrase.
I haven't driven one but I did look up it's track numbers from Car and Driver Magazine and some comparable from zeroto60times.com.
2013 Ford C-MAX Energi (EV now) 0-60 mph 16.1 Quarter mile 20.1 (@65 mph)
1980 Ford Pinto (4spd) 0-60 mph 15.7 Quarter mile 20.5
1974 Toyota Corolla 1200 0-60 mph 16.0 Quarter mile 19.7
2001 Toyota Prius Hybrid 0-60 mph 12.9 Quarter Mile 19.0
I think that makes it drivable although it's only competitive with the slowest cars listed in the zeroto60times.com data and essentially all of those cars are 1960-1980 era econoboxes or Diesels. Today's econoboxes are quite a bit faster.
I would say it should fit within the very outer realm of "full-performance".
The thing is it doesn't start up in EV mode in "ordinary PHEVs" and it does start up in mountain/hold/sport modes in "EREVs", so how important is that distinction to users if they can just push a button to change things?
Huh, I don't understand what you are getting at. The Volt/ELR do not start up in mountain, hold, or sports mode. The car reverts to "normal" mode every time you turn it on.
But series hybrid mode says nothing about whether the engine will start up if you try to accelerate too fast. It's just describing the power flow path from the engine to the wheels. It has nothing whatever to do with EREV behavior.
In fact, ironically, the ELR is almost certainly operating in series hybrid mode when it gets the 0-60 mph numbers that you think makes it a non-EREV car. The Volt has been measured with OBD-II tools doing 0-100 mph track timing and it stays in series hybrid mode the entire time. The Volt blends about 75 kW from the battery and gets another 40 kW from the generator driven by the gas engine. The ELR presumably gets 90-100 kW from the battery and 40-50 kW from the generator. It's total system power is rated around 154 kW in the latest specs I saw from Cadillac.
That sounds very convoluted. I say it's more far important to users what the actual EV mode characteristics are (0-60 and top speed) rather than whether it's a default setting rather than after pushing a button.
The goal of a driver who cares about the EREV distinction is to be able to drive the car without starting the fossil fuel engine until it's needed because the battery runs out without having to push buttons or expectantly concentrate on power displays that indicate that accelerating any faster would start the engine. Such a driver just wants to drive and not be surprised by engine startup.
- - - Updated - - -
So you are hinging the entire argument on a specific condition that is extremely rare and only lasts an extremely short time period the few times it may actually happen. And you think this distinction carries great weight and requires a completely new vehicle classification.
Certainly not.
I'm arguing that GM's notion of EREV conveys a useful and important characteristic.
The threat of starting the engine on a Prius Plugin is very real. You can conservatively drive it on flat roads up to 62 mph without starting the engine but you have to pay close attention when merging onto the freeway where the engine comes close to starting during typical driving.
The threat is presumably less on a Ford Energi (I haven't driven one yet). However, I'm guessing that it would be relatively easy to press the accelerator hard enough to start the engine when passing on the freeway or when driving up steep hills (think San Francisco or Seattle) or mountain highways. Those are common everyday driving conditions for many prospective customers.
