It looks like it would work. Car will charge slowly. For example, my wife drove our S100D to our daughter's apartment last Thursday. Her then-fiancee, now husband, connected Mobile Connector to a 120 Volt 5-15 receptacle. The car charged at 12 Amps, limit for continuous operation of the 15 Amp rated outlet. The battery added 19 KWH over the following 18 hours.
Cautions:
- The receptacle appears to be exposed to weather. It may no longer be able to safely handle its rated electric load. Proceed with caution. Electrician's fee to review and renew the arrangement is likely to be a small fraction of cost to repair damage from electrical fire.
- Adapter rated at 10 Amps. The Model 3 5-15 adapter will pull up to 12 Amps, which could overheat the receptacle or adapter. You can use the outlet to charge your car with the following procedure:
A. Before attaching cable, bring up charging menu.
B. Enable Scheduled Charging. Specify start time a few hours in the future. You can change this later, the step ensures charging will not start until you've configured the car.
C. Insert receptacle adapter, then connect Mobile Connector with complementary 5-15 adapter. Finally, connect Mobile Connector with the car's charge port.
D. Return to charge menu in car. Set maximum current to 10 Amps, it likely shows 12 Amps as max. Note whether display shows 120 Volts or 2x0 Volts (220 or 240).
E. Disable scheduled charging. Charge will start after some seconds, current draw will ramp up slowly.
F. Check receptacle and adapter for overheating using the back of your hand, which is more sensitive. If you can find the lead connecting receptacle to breaker panel, check it with the back of your hand. Check at the start and then every 15 minutes for the first hour.
- Warm, but you can comfortably press your hand against it for 10 or 15 seconds, if acceptable.
- Too hot to rest to press the back of your hand, or burning smell? Discontinue charging immediately.
- Not a problem if receptacle provides 220/240 Volts. The adapters can handle it, your car will charge at slightly more than twice the speed.
Be careful, and good luck!
