Does anyone know the caliper size and rotor dimensions of the performance red brakes vs non-performance calipers and rotors???....I am assuming its more than just a red paint job?....tia.
Most you see on here are just a red paint job with cool Telsa logo which you can pick up at one of the online Tesla accessories stores. I have not seen any drilled out rotors on any Model 3 pictures.Does anyone know the caliper size and rotor dimensions of the performance red brakes vs non-performance calipers and rotors???....I am assuming its more than just a red paint job?....tia.
The P calipers are quite different, they've got 3 pairs of pistons vs 2 on the base. The front base rotors are 320mm diameter, the P are 355mm.No I am actually talking about factory performance brake specs vs non-performance brakes from factory.
Good to know, so these are on all Performance versions?The P calipers are quite different, they've got 3 pairs of pistons vs 2 on the base. The front base rotors are 320mm diameter, the P are 355mm.
All of the ones with the Performance Upgrade Package. The "P-" Performance sold last summer/fall is physically exactly the same as the base Dual Motor Model 3, it is only a software difference.Good to know, so these are on all Performance versions?
We have a P3- and just upgraded yesterday to the 6 piston Brembo Brake Kit with the vented rotors - it even fits the standard 18" Aero Wheels, which unfortunately the now standard Performance Upgrade Package brakes don't. I think the stock brakes are fine for everyday driving, but you definitely need something better for extended hard driving - even just one medium lap at Buttonwillow raceway on the stock ones got me very nervous, and why I upgraded.
I test drove the LR AWD and the P3D back to back and brakes was the biggest difference I could feel apart from the acceleration, LR AWD is no slouch but the brakes just don't keep up.
I measured my 60-0 stopping distance at 105ft (PS4S tires). I don't see how bigger brakes would have helped, the regular brakes are more than powerful enough to exceed the available traction of the tires and activate the ABS.I absolutely agree with this...only part of my car thats bit disappointing are the brakes...just doesn't stop fast enough for such a heavy car.
The brakes don't stop the car- the tires do.
We should change the text under your name to say this after how many times we've covered it
The bite-in with the stock brakes is really lame, that does matter for driving. No way I’d go on a track with them, the lack of bite leads to faster heating & already w/pads not made for heat.I measured my 60-0 stopping distance at 105ft (PS4S tires). I don't see how bigger brakes would have helped, the regular brakes are more than powerful enough to exceed the available traction of the tires and activate the ABS.
I agree that the bite is pretty weak but I assume this was a conscious choice by Tesla. It seems optimized for smoothly transitioning from regen to friction when coming to a complete stop.The bite-in with the stock brakes is really lame, that does matter for driving. No way I’d go on a track with them, the lack of bite leads to faster heating & already w/pads not made for heat.
Pads alone will, in the short term, fix that for a lot less $. Of course if you track the car & keep pushing further you’ll come to the next choke point. Discs or fluid. Fluid is cheap, discs not as much.
At some point, especially if you go with bigger discs, you’ll outgrow the calipers, too, for sizing. Not sure I’ll ever get there myself but it is a thing.
What forum were you on before?Honestly, one of the the things I like about this forum is I've had to explain it far less often than on previous car forums where folks were just SURE that spending 5k on a BBK would knock 30 feet off their normal braking distance...the literacy on technical/physics stuff seems noticeably better here for the most part.
I was on the Subaru Legacy forum before and I remember people having more mechanical knowledge. Though I bet the bigger brakes = shorter stops misconception probably happened there too.
