Hello all
So this area to plug in your phone in the middle console of hte MX....what is the connector there? is it strictly for iphone? What if I have an android phone?
thanks
Leo
although it looks good, it doesn't work at all if you have a typical phone case. I was also concerned that it would be pretty easy to break so removed the connector. Since there are two of us who drive it and we have different styles of phone cases, that's been the best move! Note that you can have several phones sync'd via Bluetooth although only 1 can be "connected" at a time.
I have to disagree. Elon's car at the reveal was set up with a lightning connector and I could get my iPhone (in its case) slid in every time without difficulty, I tried several times without looking. It works pretty well. The trick is (and I haven't looked closely at Tesla's version, but I have similar docks here at work and at home by my computers) the cable holder is fully adjustable, you have to adjust it to fit *your* phone in its normal carry case (if you use one), etc.
That said, I agree, I'd rather have it where I can see it at eye level, at least until we get the screen mirroring he talked about in France so I can get Waze showing on my screen.
Then we just need to launch a campaign with Waze to add chargers and have an "EV route" mode as a feature.
The two guides and cables that come with Model X are very basic for the phone storage in the console. If the guide was adjustable, it would be perfect. As it is, it is hit or miss on getting the iPhone into the charge port.
Eventually I might go back to manually plugging in a coil cord into the iPhone. That would allow iTunes selection or checking the screen while stopped in traffic.
One possible problem using the phone console storage is forgetting the phone after leaving the Model X. An iPhone 6 with an Apple black leather case blends in while sitting in the charge cradle.
The thin leather case that Apple sells for iPhone 6 works fine with the charging cradle because the entire bottom of the iPhone is uncovered. The challenge is getting the lighting connector to align easily. Since the phone is too narrow to reach the side guides, it takes time to make the connection. The other set of guides is too narrow for iPhone 6 with the thin leather Apple case.Are you able to put the iPhone into the charging cradle with the case on? The case I'm using won't fit. Does the leather case help prevent the phone from slipping out of your pocket when you sit in a chair? I'm thinking maybe I need a different case.
