DNAPoPo
I get antsy when I dip below 50, lol, Some of these posts above are super ballsy!
Tell me about it. True range anxiety is having a car like the 2011 Nissan Leaf I was leasing. During the winter I was lucky to get 70 miles of range. And there’s no supercharger available for the Leaf.It somewhat boggles my mind that cars with 300+ miles rated range on a 100% battery charge still leave people running the battery dry but gee, here we are.
Bologna.
With an EV if you are really screwed you are charging on 120V and have to sit around spending hours just putting 10 miles of range back on the car.
Because I like to live on the edge ...no lol
But really, the 8 mile one, I had I think 160 miles to go 100 miles. Made it the 70 miles to destination and turning around to go the 30 to the SC, with a rated 40 left. About 10 miles in my rated dropped to same as distance to go, so found a library with public charging, had breakfast. Rolled into SC with 8. So really I was negative if not for the lucky free L2 charger I found.
The 2, I was in rural Maine. I actually had to SC 4 times that day and missed a funeral service due to it ... I actually am starting to think there is something wrong... I have been averaging 400-450 wh/mile and the temps have been above 40 and driving pretty close to highway speeds. Granted one day had rain.
That all being said, I am really impressed with SC layout in New England. I drive all over New England and have put just about 4,300 miles on my car in 3 or so weeks; the SC have been everywhere I needed them!
When I had a Leaf a lot of the time I STARTED with 50! LOLI get antsy when I dip below 50, lol, Some of these posts above are super ballsy!
Yesterday I got bit...
I was driving to the Ardmore, OK supercharger (on US 70 between Waurika and Ringling OK if you want to see on map), it was about 40 miles away and I had 70 miles on the battery. Seems like an fine margin, but do not really have a choice since there are not any other superchargers near. Well I got turned around on the highway. A tanker truck had overturned and the road was going to be closed for the rest of the day while they cleaned up an oil spill... With the required U turn and new route it would add about 60 miles to the trip... So, I turned around and started on the new route. The map of course kept wanting me to do uturns. Eventually the map changed to the new way and it was already flashing that I would have negative battery. Used search on the cell phone and found an RV park. Had to pay $20 to rent a stall and charge for about 2 hours using the 15-40 plug. So, it took about 3 hours longer (hour driving and 2 hour charging).
Lesson learned: when they finally get the Wichita Falls superstation built (still says 2018 estimate, hopefully next year), I will always stop for 10-15 minutes to get an extra 50-60 miles added. My driving route is Norman, OK -> Wichita Falls, TX-> Ardmore OK about 230 miles in an AWD model 3, usually gives me 25-30 spare miles range (highways speed limits from 65 to 75 on route). When winter comes I will probably have to slow charge at one of my businesses for a while (have a 14-50 plug) in Wichita Falls.
I had a close call this last weekend. I put in a Supercharger near to NYC on the way from Baltimore, and it said I'd arrive with 7%. OK so I drove at 65mph almost the entire way, but the temperature dropped a lot and it was raining, and about 40 miles out it said I would arrive with 2% - I dropped to 60mph, switched off all the heat and eventually arrived with 3%. I won't do that again.
Well the other learning curve will be when people get comfortable with making a trip with a tight margin and then noticing how the margin is gone when the battery gets a little older.
Last weekend I drove 1100 miles over 30 hours........ Spent a fair amount of that time at superchargers. In Mohave, CA I was charging at 117kw and a driver pulled into the spot paired with mine. I assume the supercharger hardware was faulty because the power dropped to 72kw. Grrr.. I politely told the other driver how paired stalls worked, and there was a "free pair" at the other end of the lot. He moved, and we both got to charge at full rate!1000 miles a week is an insane amount of driving to do in an electric car. Glad you have found a way to make it work.
