I'm seriously considering the Tesla Model 3 (Long Range) as a company car, i commute between Hull and Manchester on a daily basis, along the dreaded M62 travelling at Motorway Speeds of 70mph and a bit, the journey is 100 miles each way.
Taking into account the my constant and relatively high speed and the distance i'll be travelling, how close to the claimed range should I be able to get, or will traveling at this speed reduce the range significantly..... ???
are you able to schedule it though? Or will it require opening the app every morning for when you want to pre heat it?View attachment 510251Yep. This is the screenshot of smugness
You can schedule it, but I prefer doing it myself as my departure times vary during the week.are you able to schedule it though? Or will it require opening the app every morning for when you want to pre heat it?
the original question asked a page ago related I think to scheduling while not plugged in. you can only use scheduled departure when plugged in so scheduling while not connected requires a third party app or service such as Teslafi.You can schedule it, but I prefer doing it myself as my departure times vary during the week.
Ah, sorry. I missed that nuance.the original question asked a page ago related I think to scheduling while not plugged in. you can only use scheduled departure when plugged in so scheduling while not connected requires a third party app or service such as Teslafi.
I would personally say very little difference, especially if the LR has 19s optioned. My P+ has got a lifetime efficiency of 304w/mile from October, pretty much living on the motorways at the speed limit, oh and just the occasional lead foot moment from the lights (well maybe I little more than occasional lol). I'd personally say it will fit the bill very easily.Hi Jim, it certainly sounds like a model 3 would fit your needs perfectly. In terms of range on the performance over LR then there’s not much in it in the real world. Maybe someone else can confirm exact differences?
I would highly recommend trying out your journey on “a better route planner” google it and have a play around with best case (tail wind, no rain, decent temperature and sticking to the speed limit) and worst case (head wind, heavy rain, low temperature and high speed) and everything in between. Realistically you probably wouldn’t be going 20% over the speed limit in these poor conditions (reference speed means 100% compared to speed limit, therefore 120% would be 84mph on motorway). Having had a quick check, you’d be fine in almost all conditions unless you’re doing 85+ in torrential rain with a greater than 20mph headwind.
It would certainly be worth installing some charge points at work, preferably 7kw chargers at that and also a 7kw charger at home.
Should save you a ton on fuel so looks like a great option.
If you’ve got any other questions feel free to reach out to me.
Hey Jim. Here's some data from a 180mile journey at the weekend (Swansea to London).
You can see the second half of the journey had better efficiency - for a few reasons. I had the Reading roadworks (30miles at 50mph), London traffic (amazing how slow battery goes down in a city), it was warmer outside and elevation was more favourable.
I left home at 99% and arrived at 23%.
Not sure if you know this, but you shouldn't charge to 100% too often as it will speed up battery degradation (just like a phone battery will last longer if charged to 80), so your figures would need to be on 80% charge ideally. Some may say 90% is ok, depends how long you keep the car perhaps.
Another point is you mention 19" wheels, this will give you as much as -8% to -10% range than 18"+Aero. My results above are with 18" and no Aero (-4% hit or so), and tyres at 39-40psi as I like the added comfort. So again, other factors to consider when we all offer our results! 45psi will of course get you better results, and still provide a little more comfort than the C63 I'm sure, but perhaps not the Insignia depending on it's setup!
As someone mentioned, if you plan for a 5min supercharger stop, and it turns out you don't always need it - you can't go wrong. A destination charger, even better.
We all make a compromise or two with these cars, be it the extra planning or charging stops - but the important thing is, it's worth it! As you can see I'm 7000 miles in, and still think it's a truly fantastic car.
I'm just going by various threads and videos. But maybe it would be fairer to say from -6% as there are a fair few results showing that, and that's what's ABRP shows, in which case not a huge amount more than aero free 18's.Where does the minus 8% to 10% figure for 19" wheels come from? why would it be significantly worse than the -4% you mention for 18" without the aero caps
This has to be one of the most informative threads I’ve read, thanks to all the contributors and to Jim for posing the question So looking forward to my M3 LR!
m3 LRdid glasgow to warrington
started with 96%
225 miles
7c outdoor
cold battery to start
70mph on the motorway (fairly consistent with autopilot)
heating at 20c
arrived at the SuC with 11%
started with 96%
225 miles
7c outdoor
heating at 20c
