maybe it was a fluke set of cells? it was a youtube video where someone bought a few cells and tested them. Also the problem with lithium ion is always to determine what voltage counts as a complete discharge and i cant remember what he used. Particularly at low current draws you can quite significantly discharge them which is obviously detrimental to battery health...
When I did a test with my car this summer I was down to 0.39% SOC, the viltage parked was about 3.09V/cell. When driving (not very fast) the voltage was about 3V/cell or slightly less.
About 3V to 2.5V gives an average in the ball park of 2.75V.
Of the measured capacity of about 4950 mah, 4630mah was from 100%(4.20V) down to 3.0V.
This leaves in the ball park of 320mah below 3V to the discharge limit.
0.32Ah times 2.75V = 0.88Wh.
This is 4.89% of the total capacity.
Albet a rough calc, it show us that there is not much capacity left as the buffer is 4.5%.
Also, there would not be a “brick protection” above the 2.5V /cell manufacturer discharge limit, as the cell will not be bricked by getting discharged to the limit.
All specified capacity, and also all discharge tests that go to 2.5V show the “usable capacity above the safe limit of 2.5V.
Any real ”brick protection” will be below 2.5V and not a part of the real capacity.
The capacity below 2.5V will be very, very small as the cell is more or less completely discharged, and the voltage drops very steep.
I think we have data enough to draw the conclusion that the brick protection is a set minimum cell voltage of 2.5V/cell and that there is no specific capacity set. We also know that the energy below 2.5V is more or less none.
