So, we know battery degradation is a natural and will happen whatever we do. We might be able to limit the amount of degradation for some of the factors in some cases but not all.
- Small cycles is good, deep cycles is worse. Keeping the cycles small will help.
- High current is worse and small is good. Supercharge when you need, and do not when you dont.
- High SOC wear more when the car is parked, Low is better. Dont charge to higher SOC than needed, and charge as late as possible. Dont fill it up and leave it for the weekend.
- High ambient temps is bad, low is good for storage. The combination high SOC and high ambient is extra bad, so try yo keep low SOC if possible when parked during hot season. As it looks from numeorus tests, this might be the most important factor.
If you need to charge to 100% daily, then do it. If you need to keep the car parked with high SOC, then do it. If you need to use big charging cycles, then do it. Both togheter with all these comes more battery wear than if not so do not expect the lowest degradation on your street.
I guess some have seen the low degradation chart for Model S/X. Looks really good. You see the average normalized red line and think,”Thats cool. I will be on that line too”.
But:
1) Its not the 2170-battery. Its not the same application, or the same BMS.
2) Its average. About half of the S/X guys will be below at each point.
3) Its normalized. The average is smoothed to make a soft bent curve. At some points this curve isnt drawn at the average point. Look at 0 to about 15.000km. The line seems to be below the average at some points.
Some of the S/X guys was at 85-90% between 0-60000km, so they experienced 10-15% degradation quite early.
If you have to go hard on the battery, like the ”If-statements” above on a regular basis, you most probably will not be above that line.
We know battery do degrade, we also know what cause it, and we know why.
