Well, I havent seen any research results that points at low SOC causes degradation.
Actually all research reports( 30+ research reports) I have seen points towards low SOC causes both lowest capacity degradation.
I’d like a link to that scientific battery thread if possible, I’ll read it and see.
I thought I would be able to stay with easy not that deep digging posts. This will be a messy deep dig, though
There’s a lot of info in the research telling is the facts.
For capacity, degradation in lost capacity of course. For the ability to release or recieve energy, increase in IR / internal resistance and impedance tell us about the changes that causes slower charging and less power.
Low IR will also cause low heat losses during drive, so it is a good thing.
Most graphs is easy to interpret, and show us that the less SOC the less degradation in capacity and charging speed/power.
The most research resports have graphs like this: It seems like a very good idea to use the lowest SOC possible.
These might lack one dimension, it shows the increase in internal resistance (IR) for the selected storage SOC. But it doesnt show the IR over the range for one selected storage SOC.
For the one below, the first view could fool one to believe that 10% SOC is worse than 20 or 30%.
The storage SOC is shown on the bottom axis(X-axis).
The tested IR at a specific SOC is what we read in tip of each picture.
At 10% SOC the IR is high to begin with( we notice lower power). While it is possible to ”save” the IR for 10% SOC, this could be done by store the battery at 75% SOC but that would cause more increase of IR over a big range of SOC, where we like to have most power. We will also loose more capacity
![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
To the mess: we have a storage SOC, at what SOC the battery was stored. But we would like to know how a specific storage SOC affects the battery over the whole range.
As an example, the 60% SOC picture tell us how the IR was affected at 60% SOC and the bottom axis show which storage SOC the battery had.
We can see that it is a more or less straight line between 0 and 35-40% SOC, where we have the least increase in IR.
This is more or less the same for SOC between 30 and 80% SOC, and the small increase barely noticable at 20 and 90% show us that low storage SOC is better for virtually all SOC’s.
If we check the 100% SOC picture, the lowest IR Increase comes from 25-30% SOC, so a small increase if a SOC below 25% is used. Still, if stored at 0% it is better than all storage SOC above 40%.
The conclusion is that the lower the SOC when the car is used, the less capacity fade will occur. Also, the internal resistance in the most used range( 90-20%) will increase least, meaning least degradation and most power available and also least heat losses from the battery.
This picture might take a while to understand, but it is very telling, so very good info. NCA if I remember it right.
