Note: This feature currently requires accessing the site using the built-in Safari browser.
I do not have a plaid. The long range is rated for 348, while the Plaid is rated for 333, with 20 inch wheels. That means roughly a 4% reduction for being a Plaid. If you add in the 22-inch wheels, that represents another 4%.Hello folks,
I am on the fence of buying a Model X LR versus Model x Plaid.
What type of range are you seeing on Model X Plaid refresh (2022+)?
Thank you!
Isn’t plaid justnsofteare for speed or is the motor different? If you drive under granny mode, you should get more range?
Yes I understand this, but what is the range when you all go on trips let’s 80/90% charge prior to your departure. I saw an older gentleman with an X ludicrous and he mentioned 250 max at 100% chargePlaid has 3 motors Vs 2 for LR X
So many variables weather being the biggest. Se mine above that is 100% charge some hills/mountains mostly flat.Yes I understand this, but what is the range when you all go on trips let’s 80/90% charge prior to your departure. I saw an older gentleman with an X ludicrous and he mentioned 250 max at 100% charge
downhill for 348 miles.Reading through all this, then, in what world and driving setup can one achieve the 348 miles of range advertised by Tesla for a new non-plaid X?
I should be able to exceed 348 in moderate temps with no wind. The problem is, that range assumes you take it down to completely dead. This is only possible in a lab type setting where you can run it until it actually dies, then charge it. But I do often see "Estimated" range exceed "rated range," even exceeding "ideal" range. With LRR tires and a good alignment it is easily obtainable. But not at 80 mph on a windy day.Reading through all this, then, in what world and driving setup can one achieve the 348 miles of range advertised by Tesla for a new non-plaid X?
Okay, maybe not drive it to empty.I should be able to exceed 348 in moderate temps with no wind. The problem is, that range assumes you take it down to completely dead. This is only possible in a lab type setting where you can run it until it actually dies, then charge it. But I do often see "Estimated" range exceed "rated range," even exceeding "ideal" range. With LRR tires and a good alignment it is easily obtainable. But not at 80 mph on a windy day.
I don't know. My fuel gauge displays battery SoC in %. Miles in that field made no sense to me, mainly because it is a made up number. If I drive 250 miles, I would expect it to show around 20% remaining, unless conditions were less than ideal.Okay, maybe not drive it to empty.
But, starting from full charge, could you drive say 250 miles and will the meter say your remaining range is 98 miles? Or, how close to it in everyday normal driving?
Oh, I am sure mileage is tested in a lab, under carefully controlled conditions, dictated by EPA requirements. Likely why folks think the number is optimistic. In reality, at least for my car, it is very reasonable.I doubt the EPA test is done in a lab. I’m sure they’re also driving the car on regular roads, etc. So, how are they (and Tesla) saying the range is 348 miles?
windows up no climate control, crusing at 60mph and under with some stop and go traffic. No elevation change. Out side temp at 50-70 degrees Fahrenheit. No other passengers or any luggage. going from 100% state of charge to about 10+ miles pass 0%. Once you hit 0% you have about 3 kwh of battery left. If you do all this you can hit the eps rated millage.Reading through all this, then, in what world and driving setup can one achieve the 348 miles of range advertised by Tesla for a new non-plaid X?
