It's been in the mid to upper 20F's where I live the past few days. My daily commute is about 100 miles, about 3 hours worth of driving, so I decided to do some testing using the trip meters.
1. Drive normally with HVAC at 72F (A/C on, Recirculating Air) with heated seats. Energy usage average was around
350 Wh/mi.
2. Drive normally with HVAC at 60F (A/C off, Outside Air), no heated seats. Energy usage average was around
230 Wh/mi.
3. Drive normally with HVAC completely off, no heated seats. Energy usage average was around
210 Wh/mi.
For #3, I did have to crack open the windows every once in a while to help reduce foggy windows (Outdoor humidity is non-existent so opening the windows sucked out all the moisture for a short while). I was also tripled layered, wearing gloves, so I didn't freeze and the Tesla mobile app on my phone showed the interior temperature to be around low 40F's after driving a bit, which was about 20F above outside ambient. (Maybe my own body heat and other electronics warming the cabin naturally along with sunshine on a black vehicle).
When I first received my Model 3 in August, I was averaging about
215 Wh/mi when the ambient was about 70F.
So to me, it's obvious that the major cause of range reduction is my Model 3 trying to keep the cabin temperature close to 50F above ambient, for the entire duration of my 3 hour commute. I don't think there's much loss of "efficiency" due to the cold, in the technical sense. However, obviously at lower temperatures, LiON batteries suffer in the sense that the available energy available to be used when the pack is "cold-soaked" is reduced. You gain that energy back as the pack warms up.
Also, you don't see this type of range reduction in ICE vehicles in similar conditions are due to the fact you're using waste heat (it in itself, the literal definition of efficiency loss) to heat the cabin.
So moral of the story is, plan accordingly with the knowledge nuggets peppered in this thread.
EDIT: P.S. This is how you really "mess" with your energy graph when you have the HVAC to "Hi" and drive around hills a bit...
